Re: r31 diff question
From sydney
are VL diffs the same as a skyline diffs..
Posted on: 2006/11/26 12:33
From Sydney, Australia
same guts, different discs/handbrake, and 5 stud. Axles are same.
We are talking about BW78 diffs.
The only decent LSD center that I know of, is a Kaaz one at > $1500 new.
Posted on: 2006/11/26 12:52
From Perth, WA
but there is different types of lsd in the r31 diffs too
my cousin has a s3 r31 sill and his diff is 4 pin type (or something like that - its got 4 thingies in there anyway) whereas some other r31 lsd's (and non) had only 2 pin
im not entirelly sure on this, can someone shed some light on this too?
it not 4pin, but something like that - its got 4 thingies in it instead of 2, the 4 one being stronger
and he found that out the hard way, cause he rebuilt it himself (new cones, shims, tightened it all up nicely again) and had some trouble with it
Posted on: 2006/11/26 13:23
From Brisbane
pintaras are 25 spline, axles are no good, but you can use the brakes, housing and the crown and pinion (4.11), just get R31 axles and a 28 spline 4 pinion lsd, my hemi is from a VN v8 commonwhore, when i got it rebuilt they said the only way to kill the diff, is to do donuts, it stuffs the cones in the lsd, they said straight line launches are fine.
Posted on: 2006/11/26 13:56
From Perth, WA
thats it 4 pinion
so that seems to confirm a little what i said
Posted on: 2006/11/26 15:05
From Bris-Vegas
You'll be doing well to find a Silhouette LSD diff & even if you do it'll probably be worn out.
Better to get a 28 spline from a R31, then pinch an LSD centre from a EA / EB falcon or same year Fairlane.
Posted on: 2006/11/26 21:20
CA18DET '74 1200 ute project
From Brisbane, Australia
er, EB series 2 falcon onwards. . .
Posted on: 2006/11/26 22:08
From Geelong, Vic
yeah EAs have 25 spine axles, so EB onwards
my mate have a BA LSD in his EB so there are lots to choose from
Posted on: 2006/11/27 0:20
From Perth Western Australia
so will the centre out of an EB on fit straight into the r31, using the ring gear from the EB and the pinion gear from the r31?
Or do I need to take the centre out of the EB, and use the r31 ring gear?
Posted on: 2006/11/27 5:48
From Bris-Vegas
That's it..........
Bit of work involved though.
ie/ You'll need to set the backlash, pinion depth, pinion preload & main bearing float + give it a lap for good measure.
Not a job for the faint hearted........ You should be able to get all that done + new bearings & seals for around $600 at a diff shop.
Posted on: 2006/11/27 6:04
« 1 (2) 3 »
