(1) 2 3 4 ... 17 »
SUPERCHARGING A15
From Albury
Hi Guys
Is supercharging an A15 an economical way to get a good power boost ?
Is it a hard thing to achieve ?
Cheers
Bob
Posted on: 2006/11/26 6:43
Re: SUPERCHARGING A15
From Christchurch NZ
Yes it's a good way to get more power. It's not the cheapest way to go fast.
Mounting the blower is hard work.
Posted on: 2006/11/26 7:13
Forced Induction!
From South Africa
I'd say Turbo charging is going to give you more bang for buck, as far as the cost of doing the conversion goes....
as for fuel economy.... I think turbo is also going to be better, at least theoretically you can keep the engine from going into boost if you really need to limp 15miles to the next gas station....with the fuel gauge needle 4 thicknesses below the empty line
been there.... didn't make it though ...
Posted on: 2006/11/26 7:21
From San Jose, California
A supercharger appeals to me because it would be cheaper and simpler in theory for a the home fabricator to get a 4agze toyota charger for $100 to $200 and make it work.
With a turbo there are more factors to screw up.
Plus its more responsive than a turbo which is better for autocross and road racing.
A turbo may be less harsh on the driveline, and a turbo is more efficient and will make more power. But these engines aren't the best for drag racing anyhow...
The debate goes on forever.
Posted on: 2006/11/26 7:30
-Daniel
From Canberra, Australia
I like kittens
Posted on: 2006/11/27 4:43
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
See Supercharging and Turbo-supercharging.
I like twin hampster cages.
Posted on: 2006/11/27 5:11
Quite a regular
well if you choose to do it i have a charger and small top mount cooler that is yours for $300... no offers but, i paid too much...
Posted on: 2006/11/27 6:53
From Cape Town ZA
sundat1200, I like the wheels in your avatar, bloody nice...*drewl*
Posted on: 2006/11/27 7:23
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
The level of boost pressure in a positive displacement supercharger's manifold is directly related to throttle opening.
If you want to run in the negative pressure zone [vacuum] in the manifold, just close the throttle a bit more. Performance will be less of course, just the same as any other form of induction would be.
The upside is that full boost comes on within a revolution or two of the blower once the throttle is snaped open.
Posted on: 2006/11/27 7:35
Love your Datsun.
Treat it well.
From Stray-ya
I'll get in on this one just for a laugh....
Dodgeman- yes, but only if you are running a draw through. Blow through the carb and the fish-kettle is very different and a little more stinky.
The parasitic drag is always there and always more than a turbo, unless you hook up the electric clutch (SC12 &SC14), but then you need an alternative inlet for when the blower is not running.
I am in the process of putting a SC14 onto an A15- Budget build (less than $1000 AU) using the stock pistons & stock inlet manifold, & stock compression. I am planning to run a blowthrough, boxed 32/36 carby setup with intercooler (definatley required for 9:1 compression). 4-6psi to start with & 8-10 if all goes well, although I may have to decompress for that boost level.
I will draw up some plans for the blower mounts & give details of carby jets, pulley ratios etc, if all goes well.
Posted on: 2006/11/27 8:37
(1) 2 3 4 ... 17 »
