#11 Re: Any ideas?
blofly Posted on: 2006/11/30 1:34
I have the same vibration at 2600rpm which is between 60-80kmph also I think it is coming from my redline sports air filter assembly
#12 Re: Any ideas?
woody Posted on: 2006/11/30 3:36
i have the same problem with my coupe at the same speeds but its comming from the left front and ive tried 3 different sets of wheels and still no solution but it only happens when im slowing down or just cruizing at the 60 - 70 k mark but mine runs twin webers and socked ram tubes so im not sure whats happening
beats me
#13 Re: Any ideas?
blofly Posted on: 2006/11/30 4:54
maybe it is the extractors hitting on the idler arm? mine does this sometimes while deccelerating while going around a right bend
#14 Re: Any ideas?
Kodiak_gbl Posted on: 2006/11/30 5:19
in my cse I can eliminate the engine parts as the cause. This is because at those speeds, even if I shift to neuntral and no accelerate, the car still has the same wobble. hmmmm
#15 Re: Any ideas?
Datto7 Posted on: 2006/11/30 5:33
Blofly,You think your vibration is coming from your Air Filter????????
#16 Re: Any ideas?
mikeys_toy Posted on: 2006/11/30 18:54
my '69 corolla wobbles at 30mph until 35 mph; it's the brake rotors.
one is just slightly warped causing a solid pedal and solid steering, but a higher speed wobble
check your brakes at a really low speed (less than 3mph) and see if you feel and uneven drag
#17 Re: Any ideas?
mikeys_toy Posted on: 2006/11/30 18:56
oh ya;
when it's wobling, hold your speed mid-wobble and apply your brake pedal slowly until it changes (better or worse)
#18 Re: Any ideas?
Dodgeman Posted on: 2006/11/30 23:08
Hmmmm, interesting. My 1200 coupe has NO PROBLEMS with anything above 110 kph. I'm only jealous that your cars will actually GO that fast. Mine won't.
« 1 (2)
