« 1 (2)
Re: CA18 turbo camshafts into NA motor
From Central Vic
there is an early Ca18de cam and a late
the early Ca18de cam is the same as the Ca16de cam basicaly 1/2 mm more lifte and 2 degrees duration extra
and the exhaust cams are the same
this is secondhand info though
Posted on: 2006/12/10 9:33
to buy or not to buy???? OK
This is the reason I have five coupes
From Flinders View, QLD
Just been doing some searching on some other nissan sites and it seems that a basic power upgrade they are all doing to their CA18's is fitting CA16DE cams. So BigV you where right, CA16DE cams are the way to go. Soooooo, anyone out there got a spare set of CA16DE cams lying around they want to sell.
Posted on: 2006/12/15 10:07
From Perth, WA
if its anything like the rb motors, the n/a and turbo cams are the same - all that i suspect is different is the amount of overlap and advance/retardation
Posted on: 2006/12/17 6:07
« 1 (2)
