Re: WTB: electronic ignition
From Adelaide, Australia
They arent $220 either, thats for the Petronix Kit. If you buy the petronix kit from ebay its about $100 from america.
The Datrats dizzy on the other hand is about $450, feral has shut up shop from what ive heard anyway. How do you know they havent recurved the dizzy?
Posted on: 2006/12/13 12:59
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From brisbane
I was able to buy a brand new A14 Elec dissy for a B210 75-77, from Canada a while back, I still havent got a rotor & cap as I cant find one that fits, also have to get a elec coil but im not sure if that will be all the peices to make it work.
i think they came from an a13 (didnt come to aus) out b310, i have seen them on ebay
Posted on: 2006/12/13 13:01
Yep thats why I cant find Cap or Rotor for one, heres a pic
Posted on: 2006/12/13 13:13
IPRA Build
I don't know of anyone who actually has a Datrats distributor, that has reason to complain about the quality or performance, but if you can churn out a cheap & nasty version on a lathe & make it work properly, then good fortune to you, but mine came with a new module & wiring harness too.
I love it
Posted on: 2006/12/13 13:16
Love your Datsun.
Treat it well.
Dodgeman, can you shed any light on this dizzy, do I need any special coil or will a elec coil from bosch work?
Posted on: 2006/12/13 13:23
IPRA Build
From brisbane
dizzy1dizzy2
and a cap
capcap2cap3
hope this helps couldnt find a rotor
Posted on: 2006/12/13 13:33
From brisbane
dont get me wrong if it blows your hair back do it all i was trying to say is that if someone wonted one cheaper (on a budget) that is all they would have to do.
personally i have gone for a vw modified procomp dizzy with accel timming comp to control vac and mech (has cost about 600 so far).
Posted on: 2006/12/13 13:41
Sadly, I can't. I don't even know what make of distributor that it is, but knowing that would be a good start, as would knowing just exactly what engine & car it was made for.
Do we know if this was intended as a high energy ignition, or simply a standard output ignition? The High Energy types are often distinguished by a larger diameter cap so as to space the terminals further apart, & this type requires a high output coil, such as the Bluebird [& many others] use.
If you can determine the make & model number of the distributor, then give Google a bit of a flogging & see if you can come up with some info, after all, that's what the internet's for.
I wish I could be more helpfull.
[Edit] If you have one of these Crown remanufactured distributors, then the 'fit' chart on their listing will tell you just what models used it.
Armed with this info you may care to ask if any of our US members would purchase the needed parts on your behalf & mail them over. A Paypal account would be an advantage as would a double order of parts so that you aren't stranded if a cap or rotor should fail.
Then again, ebay is good.
Posted on: 2006/12/13 13:43
Love your Datsun.
Treat it well.
From brisbane
any coil will work but for better performance get a 40 000v to 45 000v coil
gt40 would do fine
Posted on: 2006/12/13 13:44
From melbourne VIC
i'm still looking for a second hand datrats unit if any1 wants to sell
Posted on: 2006/12/14 1:04
« 1 (2) 3 »
