where does the earth strap go???
From Bendigo, Victoria, Australia.
can anyone tell me where this terminal on the earth strap is supposed to go to. it doesnt reach the starter motor - but the positive one does - and there is nowhere really else for it to go as far as i can see.
Posted on: 2006/12/31 2:41
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Re: where does the earth strap go???
From perth
Hey looks it goes to the block...the same side you have it on....
Posted on: 2006/12/31 2:45
yeah but what bolt holds it in place?
Posted on: 2006/12/31 2:47
Bob Dylan
Well, in 1000's & 1200's it bolts to the timing case with one of the small timing case bolts.
Posted on: 2006/12/31 2:50
Love your Datsun.
Treat it well.
hmmm. i suppose the 1 with the bigger washer on it!
its just taken too long now to swap the engine over and i cant remember what wires went where (alliteration not intended).
thanks Dodgeman
Posted on: 2006/12/31 2:56
Bob Dylan
It is supposed to hold on to the engine block. One side is bolted on to the body. Your cable is already fastened to the body, the other end can go to one of the engine mount bolts on the engine side. That is how I got it affixed in my B210 and in my jeep.
Today I was working on my 140J and the ground strap was afixed to the body bellow the battery, at the battery seat ( metal base where the battery rests ) The other end was affixed to one bolt that was situated just behind the petrol pump and lower than said pump. That is an L18 motor. I do not remember a similar bolt on the A engine.
No problem, bolt it on to one of the engine mount bolts on the engine side.( not on the body side, rubber part is in between body and engine). I can see some naked cable there in your pix, make sure you cover it with electric tape.
Posted on: 2006/12/31 5:21
