Re: 120y 5spd gbox
From sydney
This is what it says in the wiki.
What types of 5-speeds are available?
56 series trans
small, light as in original B110 4-speed with visible ribs along case. The 5-speed versions were 1:1 fifth-gear "direct [trans]mission" (non-overdrive)
60 series trans
smooth-case medium-size trans as in B310. These come in 60L (dogleg) and 60A (non-dogleg) varieties
63 series trans
large trans commonly used with L-series engines, a version was also fitted to A-series engines in B210s. The 5-speed version is a "dogleg" shifter. It was fitted to 5-speed hatchbacks from 1976-1/2 through 1978 model years, and starting in 1977 for Canada
Finding one will be the hardest thing, as they are getting a bit thin on the ground.
Next option would be to do a Toyota box conversion, contact Dellow in Sydney they should be able to set you up with all the bits you wil need.
Posted on: 2007/1/1 22:48
Subject Poster Date
     120y 5spd gbox datsmokin 2007/1/1 22:32
       Re: 120y 5spd gbox sidedraught 2007/1/1 22:48
         Re: 120y 5spd gbox ddgonzal 2007/1/2 0:31
         Re: 120y 5spd gbox datsmokin 2007/1/2 2:18
           Re: 120y 5spd gbox sidedraught 2007/1/2 2:54
             Re: 120y 5spd gbox datsmokin 2007/1/2 3:34
               Re: 120y 5spd gbox sidedraught 2007/1/2 3:42
                 Re: 120y 5spd gbox datsmokin 2007/1/2 5:25
                 Re: 120y 5spd gbox datsmokin 2007/1/2 7:16
                   Re: 120y 5spd gbox pepper 2007/1/2 7:31
                     Re: 120y 5spd gbox Ronald 2007/1/3 2:25
       Re: 120y 5spd gbox pelon 2007/1/3 22:48
         Re: 120y 5spd gbox datsun_guy 2007/1/4 1:12
           Re: 120y 5spd gbox Mildman 2007/1/4 1:20
