« 1 (2)
Re: 120y diff
I did a bit of a writeup on my rolla diff conversion here:
http://datsun1200.com/modules/newbb/v ... c_id=24660&forum=1#132412
Also have a BW from a 120y too. Which remiinds me i should check the lengths and make sure. I was certain the brakes are what made the diff wider and not the axels but Harry states otherwise. I shoulda taken a picture :)
Posted on: 2006/12/21 7:35
Re: 120y diff
From southern sydney "the shire"
would a H165 centre fit in a H150? or would i need to replace the whole diff housing?
Posted on: 2007/1/11 9:15
Re: 120y diff
From adelaide
no it wouldnt youd need complete ute diff, borgwarner diffs are ok if you treat them right
Posted on: 2007/1/11 9:40
1200 restoration project moving slower than it actually is
Re: 120y diff
From Cape Town ZA
mad120y wrote:
BW68
They are pretty strong - ment to be stronger than h165
Pretty quotes from the Wiki...
All this axle talk has got me trampling... Here is a recent photo of my build, and I'm wondering if my 1200 GX has got a BW in it or not.
It has the removable backplate, and has 8 bolts holding the backing plate on. I don't remember seeing any tags on it, but will have a look tonight. Any ideas on which one this might be? Keep in mind that I'm is South Africa.
Going to keep it in there until it gives up anyway...
Posted on: 2007/1/11 10:48
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Re: 120y diff
From Adelaide, Australia
Thats a borg warner diff Francois,
Happy new year also!
Posted on: 2007/1/11 10:52
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: 120y diff
From Cape Town ZA
Hey cool, even more reason not to replace it immediately. It won't last for ever though, apparently the 1400 UTE has an even stronger unit, will find out a bit more about them.
HNY to you also, still need to get around to send that GX badge from the grill as well
Posted on: 2007/1/11 11:34
1200 GX Sedan
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Re: 120y diff
From Geelong, Vic
id say it wasnt a BW diff coz its in SA, but if you look under the diff it should have borg warner cast into the bottom of the housing under the pinion
oh, KE30 diffs are much wider than 1200/120y ones, definatly not the brakes
KE20 diffs are about the same size, but they arent really a strong diff
Posted on: 2007/1/11 11:36
« 1 (2)
