Re: which tie-rod ends?
From Sydney, Australia
You really need to measure things up before you go 'customising' the tierods, lower arms, or steering knuckles.
toe out? adjust the steering so that both wheels are pointing straight ahead, if you mean positive camber...then that's a little different.
Could you switch the steering knuckles?
So the different tierod diameter is causing you trouble? Meaning you have to run the original 120y stuff, which means you can't get enough toe, to keep the alignment straight ahead?
Posted on: 2007/1/13 23:37
From Townsville, Qld
here's the thing: The stanza struts need the later 120y lower control arms and castor bars as the older items wont let the stanza knuckle fit. Also, my tie rod end are typically stuck and I can't make them budge
Posted on: 2007/1/14 2:11
From Canberra
I ended up getting stanza (well thats what I asked for) tierod ends and they were the right ones.
Posted on: 2007/1/14 5:55
Since I can't get these suckers to budge I'm regrettably selling the car....
Nah, I'm going to take it to a shop
Posted on: 2007/1/14 9:19
From Canberra
probably one of the only times where "if all else fails, get a bigger hammer" is the right thing to do
Posted on: 2007/1/14 9:24
From NSW, Australia
I found the best way is to get them customised with a little extra thread. so you can use the tie-rod's you want and have enough room to set them up better than stock. We have an old dude in syd who rallys datto's and does them from home.
Posted on: 2007/1/15 5:10
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
« 1 (2)
