Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
40mm DCNF Weber for A15??
g1
Posted on: 2007/1/12 5:39
Is the Weber 40mm DCNF a good choice for an A15?, cause im getting it next week for a good price.
#2
Re: 40mm DCNF Weber for A15??
jaimecidpedro
Posted on: 2007/1/12 7:28
The DCNF differs from the DGEV / DGAV downdraft Webers ( 32/36) in the fact that it has only one shaft actuating the twin throats as opposed to two shafts in the DGEV/ DGAV downdraft Webers ( 32/36 ). Apparently these are simultaneous carbs, not progressive ( one throat valve opening at the begining while the second valve opens later on as the RPM increases) , the case of the DCNF being that both throat valves open at the same time like in the case of the 38 DGAS.
I have seen those, but never owned one. Those are supposed to be more performance oriented than the DGEV/DGAV Webers. Perhaps someone has tried one of these Webers.
#3
g1
Posted on: 2007/1/12 10:20
Yes, its non-progressive, it something like the 38DGAS...only thing slightly bigger venturi size. But the 38DGAS is a single barrel right??..
And i know that 40mmDCNF have better throttle response throughout the entire rpm range.... Any testimonies??.....How about the fuel consumption?...Any rough estimation of the fuel mpg?...thanks mates....
#4
jaimecidpedro
Posted on: 2007/1/12 10:53
This is what I got "verbatum" from the Weber literature:
Quote: The DCNF SERIES Now, the DGAS is a simultaneous 2 barrel carburetor, similar to the DGEV/DGAV ( the A and E differences within the DGV series correspond to water or electric chokes respectively) but the difference relies in the sense that both throttle valves open and close at the same time , delivering more power, at the expense of a little more fuel comsumption. What you sacrifice in fuel consumption you get back in more power band when using a DGAS carburetor. Both throttle valves ( one per throttle/barrel) are actuated , in the case of the DCNF carburetor, by a single shaft, one shaft moves, and both valves have to move along. The DGEV/DGAV carburetor ,( as well as the DGAS ) ,all have two shafts, one for each throttle valve, so each valve responds to a separate moving shaft. In the DGEV/DGAV the shafts move separately, hence the name progresive , in progression. In the case of the DGAS , both shafts move in unison, hence syncronious. I posted a pix of the DCNF in the photo album section. Apparently the DCNF is a good choice. I do not have direct experience, so hopefully someone can illustrate on the DCNF with direct experience.
#5
g1
Posted on: 2007/1/12 11:18
Thats great...Thanks alot mate....really really appreciate that.
#6
jaimecidpedro
Posted on: 2007/1/12 11:28
You are welcome !
Good to know you are interested in knowing your equipment , that makes it more fun and also allows you to enjoy it to its fullest.
#7
g1
Posted on: 2007/1/12 12:04
Yup, need to know what's the best since bigger aren't always the best....thanks again
#8
jaimecidpedro
Posted on: 2007/1/12 19:20
Make sure you post pictures in here and tell us about your progress, very interesting to see a DCNF Weber set up in a Datsun.
If you can find / make the manifolds, you could have a dual set up.. Sounds like music......
#9
g1
Posted on: 2007/1/16 5:45
Might sound like hole in my pocket with a twin DCNF setup. 40mm X 4 = 160mm.
Haha... By the way, with this single DCNF setup, what cam profile do you suggest? Other plans for this engine is to port heads, flat top pistons & adding 3 ring washers at the valve spring seat. At the moment, im stuck at choosing the best piston ( flat top & lightweight is a must ).... :)
#10
jaimecidpedro
Posted on: 2007/1/16 8:47
With all that work you can use a 270 or 300 degree cam. If you use a 300 or more cam, you will need oversized lifters due to the increased valve lift.
I want to see that DCNF ed Datsun!!! You can view topic.
