Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: PLEASE HELP ASAP
Mildman
Posted on: 2007/1/21 22:30
by BigDane on 2007/1/21 21:14:07 Cheap? An LSD, a 5spd gearbox, forged pistons, new camshaft, roller rockers, a weber carby AND a rebuild all for $3500 doesn't sound too bad....sure I might be about to do done a little cheaper but the pistons/camshaft/rockers/carby/LSD would have to come somewhere closer to $3000 at least! Quote: I reckon that's far too expensive for the rebuild. In regards to results.. but dattodude is correct in $ for results $3500 for 90hp atw is probably a bit rich. - Unless you particularly wanted to keep the original motor.
#12
sidedraught
Posted on: 2007/1/21 22:43
Find an A15 then give your mate the A15 , the car and the $3500, get him to do all the same things but with the A15 instead of the A12, if he can do all the things he says he can you will have a great car.
#13
BigDane
Posted on: 2007/1/22 1:49
ive located an A15, and mate says he'll do it for the same price. the engine costs $300. will it mount straight in or will modifictions be needed? also how much hp will that motor produce? enough to spin the wheels on tarmac? thanks alot guys for ALL of your input
#14
sidedraught
Posted on: 2007/1/22 2:38
The modifications are so minor your mechanic will be able to do them with his eyes shut, with the mods you are talking about the A15 motor will produce at least 120 HP , more than enough to spin the wheels of your 1200.
#15
BigDane
Posted on: 2007/1/22 3:52
thanks man, i have it booked in for tomoro, do you think i will have any troubles gettin the car registered with that engine and mods done to it? also is it very expensive and difficult to turbocharge that motor (A15) just for a goal in the future lol. thanks alot man
#16
Datsfullysik
Posted on: 2007/1/22 4:12
Mate my A15 has a lumpy cam, oversized pistons, heavy duty valves, twin SU's and exhaust, i can do skids in 3rd!!! so one as worked as what yours will be, you'll be laughing! Good luck
ty
#17
sidedraught
Posted on: 2007/1/22 5:00
do you think i will have any troubles gettin the car registered with that engine and mods done to it? Get the car registered first with the old motor in it or restamp the engine with the old numbers. Where do you live?
#18
datsonovic
Posted on: 2007/1/22 6:16
Yeah get some rego on the thing with the standard motor then go for an A15. As for the turbo setup Iv had a draw thru setup on my A15 for almost 7 years its so simple and once you got the turbo would cost less than 500 bucks to build.
#19
BigDane
Posted on: 2007/1/22 7:38
i live in perth, but to register the car first means i would have to repair the existing motor which is a waste of time, its pretty rooted lol. when gettin registered how strict are they, what sorta stuff do they check?
#20
boondy
Posted on: 2007/1/22 8:48
I got my ute licenced at midland it went straight over the only thing that he was really worried about was the demister fan he couldnt work out how to turn it on and he didnt say any thing about the disk brakes or Mags .have you seen the red 1200 its in Perth he wants 5700 for it the car is advertised on this site somewere
