Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
ADVICE AND HELP ON WHERE TO START FIRST or how to start
Whorida
Posted on: 2007/1/26 7:01
ok i am picking my shell of a ute on sunday ( jan 27th) and as u can see from the pitures a lot of work needs to be done.. my hubby says i have to rub back the panels and stuff...and one have any more help on how n what i should be doing first off from what u can see from the pics? i know its hard to tell from pictures n stuff but any help or advice/tips is much appreciated
kirstie! ![]() ![]() ![]() ![]() ![]() - i am putting on a normal door here i don't like the shaved look ![]() ![]()
#2
Re: ADVICE AND HELP ON WHERE TO START FIRST or how to start
Mildman
Posted on: 2007/1/26 7:03
any way to make the pics a little bigger? Bit hard to see especially the back of the ute
#3
killer1200
Posted on: 2007/1/26 7:42
I'd say get of much of it as you can sand blasted.
also make sure you dont get bored of it other wise it will never get finished.
#4
pepper
Posted on: 2007/1/26 7:43
2 words,
paint stripper.
#5
Dodgeman
Posted on: 2007/1/26 7:50
You can get the paint removed by a professional abrasive blaster, but stay away from 'sand' blasting as the sharp angular particles will damage the metal surface. A reputable place will have much better materials available that will not damage the body panels.
My car was 'lime' blasted & it was done as a paint removal exercise only, not for rust removal as there wasn't any.
#6
Burke_a_lot
Posted on: 2007/1/26 8:03
i don't much about datsun 1200's but i have reastord 2 old dodges do what the other people said get rid of the paint first then worry about the rest. do you have a engin? because if you don't you sould try going with a bigger one try something new and if it works you will be well known. (trust me) ps.(dont ask what type and how to put it in just measue it and thow it in).
#7
evilbetty
Posted on: 2007/1/26 8:42
ahhhh i saw that one on ebay ,welll i could give a bit of advice but if you want to know a few processes you can read my ute rebuild thread here
http://datsun1200.com/modules/newbb/v ... rum=1&post_id=&refresh=Go
#8
phunkdoktaspok
Posted on: 2007/1/26 11:04
Before you strip the paint and end up with a bare body sitting there gaining surface rust. Think about sorting out the tray floor, what engine you will use, then fit the engine and make a transmission tunnel, sort your wheels out and mod the front guards at the front if need be.
Then once all this is done, you can then begin to sort out the body for paint prep.
#9
1200rallycar
Posted on: 2007/1/26 11:12
i'm with phunk, make sure everythings the way you want it first, and you have a all the panels you are going to use
otherwise you're gonna double up on stripping and spraying get the back sorted and start collecting any missing bits (interior/trim) basically the more decisions you can make and stick to now the less work you will have
#10
Whorida
Posted on: 2007/1/27 3:52
