« 1 (2)
Re: opinions on exhaust wrap?
From campbelltown (sydney) australia
if youre that worried put a bit of oil all over them i find that oil never fully burns off so might be a bit of protection.
Posted on: 2007/1/16 10:09
* caution, sunglasses must be worn to view my ca18det *
From Castro Valley,CA USA
I've heard that they do such a great job of retaining heat, the metal fatigues and falls apart. It's the high heat not the rust that's bad.
Posted on: 2007/1/16 13:18
From Christchurch NZ
I heard that too.
But I still run it.
Posted on: 2007/1/17 5:13
Forced Induction!
From Melbourne AUS
well i gave the heat wrap a go
and i tell you what they must hold a shed load of heat in the primaries
the engine bay was much cooler, but the enourmous amount of heat kept in my exhaust caused a large backfire and a 1 foot flame from my exhaust within 5 seconds of switching my engine off
ive heard its pretty common for bridgeports to do that depending on your exhaust setup..
so while i liked the cooler engine bay temps
ive ditched the wrap, i really dont wanna be shooting flames when i stop to refuel
Posted on: 2007/1/27 23:37
1973 B110 A12
From Melbourne - Werribee
NOOOO
Unless you have stainless exhaust then it will corrode from the inside out!!
Exhaust gasses are fairly corrosive and this is made alot worse when you wrap them due to the sustained high temps that they will see.
i am not even convinced it is a good idea on turbo thick wall manifolds after seeing large flaky bits falling off the inside walls of these types of wrapped manifolds.
I worked in an exhaust shop for two years and that is my opinion anyway.
If you want a better option go get some ACL heat shielding material HR140GTR i think.
I worked there for a year as an Engineer and it is a good product and easily formed into a manifold or body style of shield and will stop the radiant and soak effects but will allow a bit of convection to carry heat away on the move.
Ben
Posted on: 2007/1/27 23:51
1969 Datsun 1000 Coupe
1970 Datsun 1600 Sedan
http://autos.groups.yahoo.com/group/datsun
b10/
« 1 (2)
