how do i put this in the tech section???
From Toowoomba, australia
sorry this is so long but i cant work out how to post in the tech section
Draw-through or blow-through turbo systems?
The carburettor can be mounted in two positions on a turbo-charged engine, and a great deal of controversy exists as to which is better. The carburettor can me mounted such that it feeds air into the turbo then the turbo feeds it to the engine. This is known as a Draw-Through system.Under these conditions the carburettor operates more or less as it would on a naturally asperated engine. Another school of thought says that the carburettor should be mounted between the turbocharger and the intake manifold. This means that the turbocharger draws fresh air and pumps it into the carburettor, which then feeds the fuel/air mixture to the engine. The claimed advantages of this method are that the turbocharger is always operating with its intake at atmospheric pressure for quicker response and, secondly, it doesn
Posted on: 2003/2/9 8:05
why go up and down when you can go round and round
Re: how do i put this in the tech section???
From Brisbane, Australia
(blow through sytem) doesn
Posted on: 2003/2/10 6:32
ahh yes good call
DAVE
Posted on: 2003/2/11 8:44
new article. Thanks for your contribution. Datto_dave, let me know if you're OK with me adding it to the turbo article. I've credited the section to you.
Posted on: 2003/2/11 11:56
yeah mate thats ok thanx
DAVE
Posted on: 2003/2/11 23:09
