What my car sounded like on the dyno last night..
From Sydney, Australia
http://www.youtube.com/watch?v=N8JSgLBE3PU
For those interested in numbers it pulled about 185kW/8500rpm at ~18psi.
Appears I burnt out an injector driver inside the Autronic ECU.. So I couldn't finish the dyno tune last night either. I have some jobs to do for next time.
I will need to advance the camwheels to bring the power back down the rev range a little.
We think It'll safely break 200kW next time.
Posted on: 2007/2/8 1:12
Re: What my car sounded like on the dyno last night..
From Mudgee NSW Australia
Sounds sweet chris 185rwkw is still very healthy, with 18psi sounds like you have had quite a few dramas with the autronic
My car should be tuned there next week
|ll give you a call and maybe can catch up?
Posted on: 2007/2/8 1:45
If In doubt run more BOOST
From Newscastle, Australia
hey sorry I missed it...was it aorund 11pm by the time you had the run up???
Mine should be ready very soon now that the throttle bodies are sorted. Andrew I will probably see you there at unigroup!!! i cant wait to get some track time in.
Posted on: 2007/2/8 2:11
Dont die wondering.....
Sounds like a reasonable plan to catch up. You didn't miss anything craig, was going ok, then it all fell apart when the injectors started failing.
We got on the dyno at about 9pm I suppose. Took us 2 hours to find the cause, we left Unigroup at about 12:30am.
Car ran ok for 1/2 of the way home, and limped home on 3 cylinders for the remainder.
Posted on: 2007/2/8 2:22
Hey craig and chris Ive booked for wednesday evening at unigroup so will be there from 7.00 onwards hope to see you there.
Cheers Andrew
Posted on: 2007/2/9 2:25
From Melbourne AUS
good numbers
should be an absolute weapon once sorted
good luck in the quest for 200
Posted on: 2007/2/9 3:45
1973 B110 A12
I'll try to make it. I'll bring a six pack if I come along. Not enough refreshments at Unigroup. I might have to look into installing a Coke machine there to make some money!
Thanks for the comments Ange. I hope it all turns out good too.
Posted on: 2007/2/9 4:00
From Cape Town ZA
Sounds healthy... up to here...
Do you have a dump/blowoff valve on there? It doesn't sound like it...
Checked out your webpage, one of the pictures of particular interest, was the one on the Stanza caster arms. The standard bakkie caster arms on the front suspension I bought, looks exactly like the ones from the Stanza in your pictures. Now the stupid question, what difference do they make?
Posted on: 2007/2/9 11:15
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Yes, its got an SSQV blow off valve that is 'plumbed back' so that you don't hear the psshh noise. It's illegal to have an atmo vent BOV in australia, and you may as well give yourself defect fines if you drive on the street with it making the pshh noise.
I run stanza castor arms that are machined down to the same length as 1200 ones.. They are thicker in diameter to the B110 ones. It's possible that bakkie ones have increased in size, due to the increase in engine size. by machining them down, I can modify the castor by using
washers on the eng of the castor rod, but with large diameter wheels, there is not much room for adjustment.
Posted on: 2007/2/9 11:41
Sounds good. What is the sound at the end? Is it the tires breaking traction on the dyno rollers?
Posted on: 2007/2/11 15:45
