Technical question not for the faint hearted.....
From Townsville, Qld
As I've been hacking away at my coupe for a while and severral things cross my mind and one of them I keep coming back to is engines.
I know I've already started gathering parts for my A15 but every time I think about it I feel it may not be enough for what I'm looking for. L series power would be good, LZ series would be better but I'm certain there wont be anything related to those coming up my way.
The next logical thought would be a CA18 Turbo but I don't want to run a turbo at the sprints and hillclimb events, I'd rather kick some arse in the 1500cc - 2000cc class. Bla bla bla, something about fuel injection (I forgot what I don't like about it??)
Anyway, who has knowledge and experience in running carburised modern engines? In my case I'm thinking of a CA using dual 45DCOE webers as I think they would be utilised better on that size engine providing good power and nice even toque.
Thoughts? sugestions? experience?
Posted on: 2007/2/8 2:40
Re: Technical question not for the faint hearted.....
From Flinders View, QLD
Interesting. I think the question about carbies on a CA has been asked before and there was a pic or 2 of the conversion. I cant remember how long ago it was posted, maybe in the last 6 months. Its a good idea and has plenty of merrit. AND ITS DEFINATLY DIFFERENT, which is great. Barry at the Carby Centre (in Punari ST near brake mart) may be able to help, if not steer you in the right direction. I myself am too lazy to convert back to carby but I miss the ease of being able to tune with a screwdriver not a laptop and dyno.
Posted on: 2007/2/8 3:19
Just trying to put the bloody puzzel back together
From Perth WA
well depending who you talk to they will tell your efi is better or carbs are better. Thats comparing 2 systems that are simmiler in style. like quad throttle bodies and DCOE's.
I would say efi with a good computer behind it and a well designed quad throttle body setup would be ideal. Then you can go to indovidual coils for each spark plug and other neato things like that! I would also imagine more tuneable.
My 2c
Posted on: 2007/2/8 3:46
Chris...
those are good points brought up there, anyone else want to add something?
Posted on: 2007/2/8 3:55
From Geelong, Vic
go the L series
Posted on: 2007/2/8 4:01
From California
i'm with the pig.
something right about an l-series in a b210
even though we've seen l-series so many times in 510's, it's not all that common in a sunny
for my money, i'd run a punched out l18 (lower deck height) with all the trimmings
Posted on: 2007/2/8 8:05
new engines and carbys mix but power is usually down from the standard efi setup, plus you would have a track car only, cant register legally a new engine with carbys, wont meet the emmissions criteria for engenieering.
L series would be great after seeing pig dogs creation... even in a 1200, it looks like it should naturally be there.
But a15 is nice too
Posted on: 2007/2/8 13:29
From Ipswich, QLD
i say go with the A series- bore out the a15, stroke it, twin 40's or 45's decent cam and exhaust and you will haul, my A15 has been bored out closer to 1600 twin SU's lumpy cam (mild) and a 4 into 1 exhaust 2" and this thing hauls up hill in 4th. Ive never driven anything like it. I've driven fuel injected civics and #### like that, 1.5, 1.6 even 1.8 and nothing compares!
ty
Posted on: 2007/2/8 15:49
From Malaysia
Or, go the 4age. Errmm, its not Nissan by the way, but if u dont mind, its an excellent engine.
Dual 45mm DCOE, good coils, plugs and cables can outperform a modded A15.
..and we havent touched the pistons mods, cams and comp ratio yet...
Posted on: 2007/2/8 18:41
From Barranquitas, Puerto Rico
Well, it all depends on your taste. I am running a weber 32/36 carb or something like that on my A15 in my 210 and it works perfect. But if you think you'd like that carb try to talk to people that have that same setup.
Posted on: 2007/2/8 18:49
Project R- The Real Tuner Club
