last time!
From Wagga Wagga
ok how do I get tyers for my 120Y there 12" and I can't find 12", can you put 13" on? and how?
Posted on: 2007/2/10 18:46
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
Re: last time!
loose the 12" wheels and get a set of 180b or sunny or stanza 13" wheels from a wrecker .... will make life easier in getting cheap tyres
Posted on: 2007/2/10 18:52
Re: last time!
From Wagga Wagga
but going from 12" to 13" would it be lose or something
Posted on: 2007/2/10 18:55
A15 Engine
5 Speed Sunny
H165 Diff
Re: last time!
what ??????????
loose ... get rid of ... throw away ... dispose of .... the 12" wheels and tyres and get a new set of 13" wheels with tyres on them. you should be able to get something from most wreckers. if you cant find a datto set a corolla set will do the job as well ............
Posted on: 2007/2/10 19:00
Re: last time!
From Wagga Wagga
so you just throw the 13" straight on?
Posted on: 2007/2/10 19:01
A15 Engine
5 Speed Sunny
H165 Diff
Re: last time!
From California
i think there's still a good selection of 12" tyres if you happen to live in japan or england
Posted on: 2007/2/10 19:08
Re: last time!
From Wagga Wagga
ha ha ha Thats it im going to but a good set of 13" tyres if they fit or not.
Posted on: 2007/2/10 19:11
A15 Engine
5 Speed Sunny
H165 Diff
Re: last time!
12" s are still available but for the availability and the cost you can get 13"s, it's not really worth it in chasing 12"s unless youreally want to keep it original.
and yes you can just put the 13" wheel and tyre straight on to your car, you'll have no issues or problems with tyre clearance. if you get some tyres with tread you may even find your 1/4 mile time will be better due to added traction and the bigger rolling diameter of the tyre
Posted on: 2007/2/10 19:12
Re: last time!
From Wagga Wagga
ok thanks bro
Posted on: 2007/2/10 19:20
A15 Engine
5 Speed Sunny
H165 Diff
Re: last time!
13" wheels are really the default standard for all small Datsuns these days.
As Boofhead said, just buy some Stanza, 1600 or 180B wheels with tyres [thats t-y-r-e-s] & bolt them on your car. Use the wheel nuts from the donor car if you can round them up as they are made from a larger section material & offer a bigger 'seat' in the rim, but if not, then don't lose sleep over it.
If you keep the tyre size reasonably small [standard size] then you should have no problems.
Posted on: 2007/2/10 19:24
Love your Datsun.
Treat it well.
