radiator
dose any one have a good radiator and how much for my 1200 85 ute
Posted on: 2007/2/13 9:52
Re: radiator
From SE Melbourne
Have a look in the classified section of this forum.
I saw one for sale in this thread a few days ago....they come up pretty often.
http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=25807&forum=2&17
Posted on: 2007/2/13 9:57
Mildman, Datsunless
Re: radiator
From Tamworth , NSW
i wouldnt pay more than 50 bucks, i think i sold one a while back for 10 or 20 bucks. cant remember which.
you can put gemmy radiators in as they are a bit bigger but fit pretty good from what i seen, not sure exactly what model. do a search on gemini radiator
btw, add your location if you want any kind of success
Posted on: 2007/2/13 9:59
Re: radiator
I took my radiator to be serviced by a radiator place. They took it apart & it was obvious that it had passed its use-by date with the corrosion & blockages, so I had a new core fitted.
I made sure I fitted a cheezecloth condom filter into the top tank [it goes in the top rad hose fitting, then fold over it & is held in place by the hose.]
This ensured that the rubbish from the block was not going to block my new core, & sure enough, the amount of junk it has trapped is amazing.
A very good investment I thought, both the new core & the filter & I've never regretted the few extra dollars that it all cost.
Posted on: 2007/2/13 10:06
Love your Datsun.
Treat it well.
Re: radiator
From Tamworth , NSW
is that condom filter something you can get from any radiator or parts shop??chemist???
Posted on: 2007/2/13 10:08
Re: radiator
From Perth, Australia
Whats the go with N14 Pulsar radiators?
I called nissan and get get a brand new one for $260. Do all the CA18 guys run these? and can one be fitted to a A series engine?
Cheers
Daniel
Posted on: 2007/2/13 10:10
Re: radiator
From SE Melbourne
a picture would tell a thousand words....
Mildman, Datsunless
Re: radiator
the pulsar radiators are an easy fit ....
with a well worked A12
with a stock 12A rotor
make sure you get the rubber donut things for the top and bottom mounts.
Posted on: 2007/2/13 10:17
Re: radiator
Not too shy to talk
From Brisbane
i run a tf gemini radiator in my ute (same hose size) got it for $200 new about $80 cheaper than a recore. can see the gauge move as the thermostate opens and closes. unfamiliar with these condom filters though that may explain the kids
Posted on: 2007/2/13 10:18
Re: radiator
Awesome, looks like i will be getting a Pulsar item then. Cant complain $260 for a brand new genuine Radiator.
Posted on: 2007/2/13 10:21
