Re: 78mm 1567cc pistons
From Enid Okla
Pin size not a problem, but mazda piston is longer, also look at weight, lighter the better. Longer skirt area increases drag and operating temp also may interfear with shaft counter weights. A15 piston lenght is 65mm mazda is 77mm.
Posted on: 2003/2/13 15:55
Subject Poster Date
     78mm 1567cc pistons D 2003/2/13 8:52
       Re: 78mm 1567cc pistons dattoman_1000 2003/2/13 12:12
         Re: 78mm 1567cc pistons datto_dave 2003/2/13 12:42
       Re: 78mm 1567cc pistons JEM 2003/2/13 15:55
         Re: 78mm 1567cc pistons D 2003/2/13 23:16
           Re: 78mm 1567cc pistons 1200rallycar 2003/2/14 7:43
             Re: 78mm 1567cc pistons D 2003/2/14 11:46
               Re: 78mm 1567cc pistons 1200rallycar 2003/2/14 12:00
                 Re: 78mm 1567cc pistons D 2003/2/14 12:21
               Re: 78mm 1567cc pistons dattoman_1000 2003/2/14 12:22
                 Re: 78mm 1567cc pistons D 2003/2/14 12:36
                   Re: 78mm 1567cc pistons Matt 2003/2/14 18:39
                     Re: 78mm 1567cc pistons dimlight65 2003/2/14 20:56
                       Re: 78mm 1567cc pistons Matt 2003/2/15 6:42
                         Re: 78mm 1567cc pistons D 2003/2/15 12:29
                           Re: 78mm 1567cc pistons Matt 2003/2/19 8:48
                             Re: 78mm 1567cc pistons Matt 2003/2/19 9:00
                               Re: 78mm 1567cc pistons Matt 2003/2/19 9:49
                                 Re: 78mm 1567cc pistons Matt 2003/2/21 9:27
                                   Re: 78mm 1567cc pistons 1200rallycar 2003/2/21 11:57
                                     Re: 78mm 1567cc pistons D 2003/2/24 6:46
                                       Re: 78mm 1567cc pistons rally-a-coupe 2003/2/24 6:58
                                         Re: 78mm 1567cc pistons D 2003/2/24 23:17
                                           Re: 78mm 1567cc pistons rally-a-coupe 2003/2/27 8:32
                                             Re: 78mm 1567cc pistons Matt 2003/2/28 18:25
                                               Re: 78mm 1567cc pistons Matt 2003/3/6 9:20
                                                 Re: 78mm 1567cc pistons D 2003/3/6 13:46
                                     Re: 78mm 1567cc pistons Matt 2003/3/22 13:13
                                       Re: 78mm 1567cc pistons D 2003/3/23 12:16
                                         Re: 78mm 1567cc pistons Matt 2003/3/23 12:47
                                         Re: 78mm 1567cc pistons ddgonzal 2003/3/24 1:37
                                           Re: 78mm 1567cc pistons Matt 2003/3/24 10:15
                                           Re: 78mm 1567cc pistons barpk 2003/3/24 21:00
                                             Re: 78mm 1567cc pistons ddgonzal 2003/3/25 6:27
                                               Re: 78mm 1567cc pistons Matt 2003/3/29 10:20
                                                 Re: 78mm 1567cc pistons Matt 2003/3/29 10:27
                                                   Re: 78mm 1567cc pistons dattoman_1000 2003/3/29 11:34
                                                     Re: 78mm 1567cc pistons Matt 2003/3/30 11:41
                                                       Re: 78mm 1567cc pistons D 2003/3/30 14:14
                                   Re: 78mm 1567cc pistons Matt 2003/3/23 12:53
