(1) 2 3 4 ... 9 »
Buying a 1/4mile race car
From Saskatchewan Canada
I am in the process of buying 4door Gx racer with the following specs:
2 x modified Sidedraught Webers 40mm.
1 x Exhaust branch,custom build.
1 x 57mm Freeflow system,custom build.
1 x A15 Nissan Cyl head,Gasflowed by TTT.
8 x Double valve springs.
Stock rockers and pushrods.
1 x Intake manifold,Gasflowed by TTT.
1 x 310 deg Custom Camshaft,done by Dirk.
4 x 60 thou oversize stock 1400 pistons(Nissan)(Balanced + Pocketed)
4 x Stock Nissan conrods(Balanced)
Geniune Nissan Rings and Bearings.
1 x 1400 Nissan Crank,knife edged and balanced.
1 x LUK clutch kit.
1 x Nissan A14 Block.
1 x Alfa fuel press. regulator.
1 x Accel high voltage coil.
Compression ratio: Dangerous !
1200 GX Gearbox,4 speed
Alfa limited slip Diff.
Traction bars.
What do you guys think?
Posted on: 2007/2/13 16:02
1400 bakkie -sold
1200 GX 4 door -sold
Re: Buying a 1/4mile race car
From Bris-Vegas
1.5mm machined out of the bore diameter!?
Don't know a lot about A14's, but in a lot of engines you'd be getting close to the water jackets.
Posted on: 2007/2/13 19:47
CA18DET '74 1200 ute project
From Adelaide, South Australia
sounds good to me.
Posted on: 2007/2/14 3:29
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Tamworth , NSW
i live my life quarter mile at a time.
Posted on: 2007/2/14 4:10
From South Africa, Bloemfontein
Hi Sparky
Great idea.
I am just a bit worried about your gearbox for drag racing. GX 4 speed does'nt say anything. As far as I know it is just a standard 4 speed and according to some guys on this website they are a bit weak.
See if you can put in a bakkie 5 speed. Willing to pull 500kg on the back tells me it will be willing to do the 1/4 mile.
Otherwise sounds great.
If you want, I can PM you Minnesh's number so that you can get some more ideas for your GX.
He was in one of those Speed & Sound issues with that quick naturally aspirated A14 powered Datsun 4 door sedan.
Something like 13.8 seconds 1/4 mile in Durban.
Let me know.
Posted on: 2007/2/14 4:18
1977 Datsun 1200GX
Quite a regular
From Garsfontein Pretoria South Africa
Hallo there,
Getting to the gearbox, the Bakkie gearbox is strong but i blew mine around 200km/h.
same sort of spec as below,
just be sure there is enough oil in there( you must over fill it ) 1200GXman gan you please send me that Number?????
Cheers Sakkie,
Posted on: 2007/2/14 4:28
If The Road is Straight Make it Sideways
From brisbane
is it going to be a drag car or a shopping trolley?
wheres the turbo,or nitrous?hell,its not even a v8.
Posted on: 2007/2/14 10:24
From Brisbane
yerr i agree with dat383, circuit car maybe?
Posted on: 2007/2/14 11:04
I am not a great fan of turbo and stuff,sure they make alot of power but anyone with the money can have a fast turbo car.
Having a normally asperated thats really strong takes some brain power!
Posted on: 2007/2/14 13:52
1400 bakkie -sold
From sydney
An NA A series can be a great little performer but they are not going to set the world on fire as a drag racing motor.
Posted on: 2007/2/14 19:23
(1) 2 3 4 ... 9 »
