#41 Re: sr16ve in datto 1000
matbighat Posted on: 2007/2/13 17:37
we should prolly start a new thread for the ga16de but oh well
the rwd version comes in some weird nissan minivan or sportute
if you can source one, you'd be better off having an importer get you both the motor & tranny since the head has that fwd dizzy issue
#42 Re: sr16ve in datto 1000
matty Posted on: 2007/2/13 19:38
racinaround - what class does your Sentra compete in?
Matty
#43 Re: sr16ve in datto 1000
racinaround Posted on: 2007/2/14 13:29
matty, look at your pm
#44 Re: sr16ve in datto 1000
perthute Posted on: 2007/10/6 3:40
any progress mate
#45 Re: sr16ve in datto 1000
Targa_B130 Posted on: 2008/6/1 23:50
I can tell you what I have done , so you know its not speculation.
I got an S14 RWD complete engine (de) cheap.
Bought an Sr16ve VZR FWD engine.
Completely dismantled both.
Put crank / rods / pistons into S14 block.
They go straight in (same journels etc:)
Blocked up an oil return in head, put a restrictor in the front of the RWD block.
Fitted SR16ve front cover and oil pump to RWD block.
Adapted head as per SR20 forums / tap head , block existing hole and feed oil to cams from oil pump using steel braided line.
As it is going in my rally car I have no concerns about mdding the firewall to clear the cam solenoids or dizzy.
I did look at remotely mounting the solenoids , and may well address this at a later date, modified standard dizzy to fit CAS.
I did it like this mainly as a time saving thing, Its easier/faster to swap blocks than muck around making adapter plates etc: and I already run a A15 with a silvia 6 speed gearbox, so I can fit a standard bellhousing to the gearbox and it will bolt stright onto the SR20 block.
You need a link ecu or similar.
Need to swap around inlet plenum or make a custom one./
Its pretty easy to make 180hp from one of these sr16ve's so its quite an economic way of making a good drunty engine compared with spending 5 grand on an A15 to make less power .....
Happy to assist anyone needing help with htis pm me .
#46 Re: sr16ve in datto 1000
converted Posted on: 2008/6/2 0:24
pic pics pics pics!!!!!!!!!!!!!1111
Im very interested in this exercise...
as you know the ve engines are very strong and rev hard. The ecu to do cam timing is also complex and really cant be replicated on an aftermarket ecu unless the tuner is einstein.
I would love to see pics and the end result.
I looked inot this idea, but at the time 2 years ago there was nowhere near enough infor around. I heard of it being done once however no specifics as to how it was done and how successful it was.
Tell me are you using the VE head on the S14 block?? How are you planning to overcome the dizzy sticking out of the head which will interfere with the firewall once in the car? If you delete the dizzy then you can use the factory ecu. Im my class of racing if i cut the firewall that was also illegal.
Anyways very interesting please keep us posted.....
#47 Re: sr16ve in datto 1000
perthute Posted on: 2009/1/23 1:42
did anything happen to this lil beast
#48 Re: sr16ve in datto 1000
dattosans Posted on: 2010/4/8 1:23
i just found this.. i think this will be sr20de.. hmm
« 1 2 3 4 (5)
