Re: Electrical gremlins on Dyno New CA18det
From Kingsley, Perth, WA
Sounds like a problem I had after 6000rpm under higher boost - turned out to be 2 things: 1. too large a plug gap (running 0,6mm now with a MSD setup. 2. rotor phasing.
I know your engine doesn't run a dizzy, but check your crank angle sensor (trigger angle) and if you've set it up for rising or falling edge trigger, and the coil charge time. Mine also felt like the engine would lit a rev limiter.
Posted on: 2007/2/15 12:51
Subject Poster Date
     Electrical gremlins on Dyno New CA18det ca18det_man 2007/2/14 21:08
       Re: Electrical gremlins on Dyno New CA18det BUNDY351 2007/2/14 22:21
         Re: Electrical gremlins on Dyno New CA18det ca18det_man 2007/2/15 3:28
           Re: Electrical gremlins on Dyno New CA18det BUNDY351 2007/2/15 3:52
           Re: Electrical gremlins on Dyno New CA18det tappet 2007/2/15 6:24
             Re: Electrical gremlins on Dyno New CA18det ca18det_man 2007/2/15 8:57
               Re: Electrical gremlins on Dyno New CA18det dattodude 2007/2/15 9:04
                 Re: Electrical gremlins on Dyno New CA18det ca18det_man 2007/2/15 9:06
                   Re: Electrical gremlins on Dyno New CA18det dattodude 2007/2/15 9:11
                     Re: Electrical gremlins on Dyno New CA18det ca18det_man 2007/2/15 9:15
                       Re: Electrical gremlins on Dyno New CA18det dattodude 2007/2/15 9:16
       Re: Electrical gremlins on Dyno New CA18det dattodude 2007/2/14 22:36
         Re: Electrical gremlins on Dyno New CA18det Grunterhunter 2007/2/15 2:59
       Re: Electrical gremlins on Dyno New CA18det phunkdoktaspok 2007/2/15 9:51
       Re: Electrical gremlins on Dyno New CA18det dattodude 2007/2/15 10:22
         Re: Electrical gremlins on Dyno New CA18det short-coupe 2007/2/15 10:49
           Re: Electrical gremlins on Dyno New CA18det bones 2007/2/15 12:51
             Re: Electrical gremlins on Dyno New CA18det ca18det_man 2007/2/23 8:20
               Re: Electrical gremlins on Dyno New CA18det BUNDY351 2007/2/23 9:14
       Re: Electrical gremlins on Dyno New CA18det dattodude 2007/2/23 13:35
