Re: 78mm 1567cc pistons
From Perth
I'm using Mazda UC pistons
4KRY2699 from the ACL catalogue
I have milled the tops off so there is no dish left at all.
Mazda pin height = 30.58
Piston length = 62.48
I have A15 crank in A14 block
0 deck height
12.9:1 static.
I really think I need valve reliefs cut however 2 engine builders have torn my motor down and rebuilt it and say its O.K.Then again I think the cams way too small.So maybe thats why I didn't need any valve reliefs.
Posted on: 2003/2/14 12:22
Subject Poster Date
     78mm 1567cc pistons D 2003/2/13 8:52
       Re: 78mm 1567cc pistons dattoman_1000 2003/2/13 12:12
         Re: 78mm 1567cc pistons datto_dave 2003/2/13 12:42
       Re: 78mm 1567cc pistons JEM 2003/2/13 15:55
         Re: 78mm 1567cc pistons D 2003/2/13 23:16
           Re: 78mm 1567cc pistons 1200rallycar 2003/2/14 7:43
             Re: 78mm 1567cc pistons D 2003/2/14 11:46
               Re: 78mm 1567cc pistons 1200rallycar 2003/2/14 12:00
                 Re: 78mm 1567cc pistons D 2003/2/14 12:21
               Re: 78mm 1567cc pistons dattoman_1000 2003/2/14 12:22
                 Re: 78mm 1567cc pistons D 2003/2/14 12:36
                   Re: 78mm 1567cc pistons Matt 2003/2/14 18:39
                     Re: 78mm 1567cc pistons dimlight65 2003/2/14 20:56
                       Re: 78mm 1567cc pistons Matt 2003/2/15 6:42
                         Re: 78mm 1567cc pistons D 2003/2/15 12:29
                           Re: 78mm 1567cc pistons Matt 2003/2/19 8:48
                             Re: 78mm 1567cc pistons Matt 2003/2/19 9:00
                               Re: 78mm 1567cc pistons Matt 2003/2/19 9:49
                                 Re: 78mm 1567cc pistons Matt 2003/2/21 9:27
                                   Re: 78mm 1567cc pistons 1200rallycar 2003/2/21 11:57
                                     Re: 78mm 1567cc pistons D 2003/2/24 6:46
                                       Re: 78mm 1567cc pistons rally-a-coupe 2003/2/24 6:58
                                         Re: 78mm 1567cc pistons D 2003/2/24 23:17
                                           Re: 78mm 1567cc pistons rally-a-coupe 2003/2/27 8:32
                                             Re: 78mm 1567cc pistons Matt 2003/2/28 18:25
                                               Re: 78mm 1567cc pistons Matt 2003/3/6 9:20
                                                 Re: 78mm 1567cc pistons D 2003/3/6 13:46
                                     Re: 78mm 1567cc pistons Matt 2003/3/22 13:13
                                       Re: 78mm 1567cc pistons D 2003/3/23 12:16
                                         Re: 78mm 1567cc pistons Matt 2003/3/23 12:47
                                         Re: 78mm 1567cc pistons ddgonzal 2003/3/24 1:37
                                           Re: 78mm 1567cc pistons Matt 2003/3/24 10:15
                                           Re: 78mm 1567cc pistons barpk 2003/3/24 21:00
                                             Re: 78mm 1567cc pistons ddgonzal 2003/3/25 6:27
                                               Re: 78mm 1567cc pistons Matt 2003/3/29 10:20
                                                 Re: 78mm 1567cc pistons Matt 2003/3/29 10:27
                                                   Re: 78mm 1567cc pistons dattoman_1000 2003/3/29 11:34
                                                     Re: 78mm 1567cc pistons Matt 2003/3/30 11:41
                                                       Re: 78mm 1567cc pistons D 2003/3/30 14:14
                                   Re: 78mm 1567cc pistons Matt 2003/3/23 12:53
