« 1 ... 51 52 53 (54) 55 56 57 ... 91 »
Re: Datsun 1200 ute restoration and sale
From melbourne
ok another small update,
over the weekend i was going to do more priming but it was to dam hot to be sanding all day so had a bit of a break fron that,and started something else that i think yous should like ........
basicly i got this idea from a guy at work ,its nothing to dramatic but you know how if you have air shocks in the back of your car you can go to a servo and pump them up with there air hose thing????well this takes that idea just a little further ,
for this i need several things ,which i have almost got all the bits and pieces togethher,
you need the shocks air shocks ,im using munroe heavy duty gas air risers which seem to be doing the trick nicely,
also you need a small air compressor or 2 depending on size wieght etc etc
also the lines to the air shocks and hoses to connect it all to gether ,hose clamps fittings etc etc
ok so im going to go thru what ive done so far so you can get an idea of whats going on,
first i had to mount the air lines that connect to the shocks,this is pretty easy they just push in and screw on,then you have to hook the lines up out of the way ,i used zip ties and special locking zip ties to do this part.............
you can see the air line connected to the shock in that pic.......
there you can see the two lines connected..........
here you can see the air lines being routed to there intented location ,they are attached up under the tray bottom and ive used plastic tubing to protect them as these lines are very thin
ok so thats the shocks in and the air lines mounted and ready to hook up ,
now from here most people seem to put a t piece at the end of these lines and then mount the t piece somewhere at the rear so it is easy to access when you want to fill up the shocks ,
now im doing something slightly differnt ,im still using the t piece as it just so happens it fits into my plumbing set up rather well so im going to keep it in there,but more about the plumbing side a bit latter when i get to that,
first the air compressor ,now this is a 12v 150 psi air compressor ,it looks pretty cool 2,not that your ever going to see it but it looks pretty cool,so i decieded to mount this up under the tray on the inner left hand 1/4 panel ,placing it here keeps it well hidden and out of the way ,also it keeps the tray area a little more clear so you dont have hoses and cables running all over the tray ,and also i wanted to put it here so i did ,hahahaha ,so heres the small air compressor finally mounted after a huge effort ,this was a bit of a tight area to work in,as regards to drilling and screwing etc
sorry bout the pics they arnt to good a didnt take them as i was doing it as the dam batterys went flat so you will just have to bare with me on this part.......
that one was looking up from the bottom at it....
and another similar shot
notice the plastic tubing to protect the wiring and also the holes i drilled into the inner 1/4 were fitted with rubber grommets to protect the cables,pipes etc
ok so in that one you can see the compressor mounted,the main air tube coming off the compressor and going into the 1/4,also the wiring ube going in to the 1/4 and at the top there the 2 air hoses from the shocks going into the 1/4,
Posted on: 2007/2/19 1:58
From melbourne
heres one with text so you know what im on about...............
and another.....
and at the moment thats basicly it till next week end ,but before i go this is where the lines etc are ending up at this stage.....
so there you have the power cable,the air lines and the compressor air hose all together in the same area just in the tray area a good spot as the tray service panel will hind everything nicely and also give access to service the system.........
Posted on: 2007/2/19 2:15
From melbourne
ok heres the dodgy scketch of the system
Posted on: 2007/2/19 3:24
www.pistonvsrotor.com
Go to the address abobe and see all the classic Racing car Toy Starlet-Datsun-Mazda rx7 and rx8...2 rotary engine with elapce time of 7.2seg... Hey Talk to the ownwer Joshua send you.........
Posted on: 2007/2/19 18:15
From melbourne
umm yeah ok not sure what your on about there mate but this is a thread for my rebuild and sale cheers
Posted on: 2007/2/20 1:05
From south coast nsw
very nice.how much travel do u have?
Posted on: 2007/2/21 9:19
From melbourne
travel well theres about 2 and 1/4 inches
from sitting with no air in the shocks and with the shocks full of air ,
all round the rear suspention is nice and firm with the new shocks and the leafs being reset and a nother leaf added plus all the super pro bushes ,it feels nice and firm,even with the shocks pumped up full it remains nice and firm ,
ok well after some time i finaly managed to get the front struts together ,these are the standard ones that will be used ,but im also going to build a set of custom struts so the ute can be lowered nicely all adjustable im hoping
but for the new owner heres the details on the standard struts completeds::::
new wheel bearings
new gabriel gas inserts
new disk rotors
standard springs
every thing baremetaled and
resprayed up with 2pak high gloss black paint
they look pretty good me think
Posted on: 2007/2/23 7:41
From melbourne
Well that was a ####ing mission wasnt it!!!!
god dam it i didnt realise the time ,ive been working on the ute since 8 this morning ,and im exhausted!!! got a little bit done thought so a small update to follow.............
Posted on: 2007/2/24 9:15
From melbourne
so yeah today was a big day got a little bit done but was rather dissapointed with a few bits,
namley the wheel tub and the state of the tray floor ,lucky im using something over the top of it so no one will have to look at it,lol
any way so heres what i managed to do first at 8.00 in the mornig this is what i was faced with as the task had it......
Posted on: 2007/2/24 10:15
From melbourne
so next had to get rid of that mess so started with some 80# sand paper and serveral sheets later and a few hours too i ended up here................
you can see the state of the wheel tub ,i wasnt too happy about that ,i really didnt want to put alot of filler in it,but ended up having to use filler to at lease take away some of the bumpys ..........
Posted on: 2007/2/24 10:27
