blind wrote:
Hey datodude,I'm running coolant and the previous owner did aswell and i cleaned all the ports when I rebuilt the engine. I hope I can find and solve the problem because my gx is suffering and i know that the double valve-springs is softer as a result of the heat, because it can not rev more than 5600rpm.
Might sound stupid, but is your timing also correct, timing can also cause an engine to run hotter than normal. Might also point to why your car won't rev past 5600, which is very low.
I learnt a trick with thermostats. It pays to drill a hole in the upper part of it, a small hole. That is insurance against a sticking unit. If that happens, you will run warm, but not boiling hot.
We also do this, drill a small hole on the rim/flange of the thermo, about 3mm. It pre-curcilates the water, so that you have less thermal shock when the thermo opens. Some production thermo already has a little hole with a little piece of copper rod through it pinched on both sides.
