Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: 1200 coupe problems
1200sedan
Posted on: 2007/2/23 11:08
Cheers for all your suggestions, everything going sweet, just trying to sort out an a15. The only problem i have is the crossmember, i cant find that template, and 1200 utes are pretty rare in nz.
#12
blofly
Posted on: 2007/2/23 22:54
You can get away with some steel flat bar 3 or 5mm thick just line the engine up in the bay supported by the lifting tackle with the gearbox bolted to the engine and the gearbox crossmember bolted to the car, then it's just a matter of lining up where you want the engine to sit, measure the distance between the engine mounts and crossmember points where the engine used to sit and cut a piece of flat bar then drill holes where you need to attatch the engine mount to and where you need to bolt the flat bar to the crossmember.
I have a bad temper when working on cars actually I just have a bad temper all the time and I still manage to make the datto work, I even managed to successfully install the head gasket upside down causing coolant to flow out of the back of the head between the block and head so don't wory about working on the car if I can do it a monkee with a hammer and a roll of duct tape could probably do a better job You can view topic.
