so after a very long day and awww yeah before i go on,while i was grinding the last hook off some how a tiny spec of metal flew off and got me in the eye thru my safetey goggles!!!! talk about bad luck ,now its still stuck in there and is anoying the hell out at me ,so to the new owner see the terrible #### i have gone thru to produce this ute!!!!!!! hahahahhaha ok well ive had my winge so where was i ,
awww yeah after a long day of hard work got up to the cleaning up stage and masking up ready for primer so here we are........
i like this stage of the day as when your up to the masking you know its nearly there ......
so a couple coats of etch and then the first coat of 2 pak primer ........
now surely that lookis a little better than this??????
so finally after 4 good heavy coats of 2 pak this is where i got ,that black square in the middle is there the fuel tank service door thing goes i just painted it black so there wasnt white edges fron underneath,,,,
heres the tray lip primed with the hooks removed.....
bit of black for the edges...
and heres the main part all primed.....
so there you go ,its now 1 in the morning im stuft so of to bed ,got a little more work to do on that area soon maybee tomorrow if i get the time,will take yous though the doulble putty process ,a process that makes things alot neated and alot straighter in the long run ,but more on that next time enjoy..................................................................................
