Stanza Diff description
From Toowoomba Q Australia
Hi guys. I'm going to sell a diff from a '81 manual 5sp Stanza. It has coil rear & drum brakes.It seems to be a stock open diff.
It has four rods that keep the whole thing under the car during suspension travel. Is this what is refered to as a 4 link or is there a more accurate term ? Also I was going to list the track width . Is this the measurement from center of tread to center of tread.
Does the hand brake set up normally stay with it.Is there any other crucial info I should list ?
Thanks heaps
Posted on: 2007/2/25 20:51
Re: Stanza Diff description
From T'ville
it is technically a 4 link but known as a traling arm link setup. i usually measure from the drum or disc face that the wheels mount to. and the handbrake setup is normally left on unless you wanted to keep it.
Posted on: 2007/2/26 3:14
