« 1 ... 4 5 6 (7) 8 »
Re: Building the A-series???
From Vancouver WA. U.S.A.
I will try to get some pics up and of the head today
Posted on: 2007/2/15 13:52
BE sure to check out my coupe build thread and feel free to leave comments good or bad.
[url=http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=36107&fo
OK I didnt get a chance to get the pics up
I found an A-15 complete short block for $150 that i can get and start building the intake has oval ports and so does the head,
so i am correct that would be the good head to use? w/the dual su setup?
Also some one said something about the fact that the stock transmission drops 2800rpm between gears I have a dogleg 5speed for mine
Or teh other option is build the a-12 buy the pistons from bob and go from there, I am close to starting work on it so any help is apreciated?
Posted on: 2007/2/16 0:51
From Selah, Washington
Greasemonkey, you found another A15? or were you wanting mine?
Mike
Posted on: 2007/2/16 1:43
I found another but iam still interested in yours what were you wanting for it?
Posted on: 2007/2/16 4:56
well i cant get the pic to load but the intakes are oval
Posted on: 2007/2/23 1:31
Also I cant find any casting marks on the head.
But if it has double valve springs and oval intake ports and a heart shaped looking comustion chamber than its a GX head?
Posted on: 2007/2/27 15:43
I was wondering if some one can give me some cam specs and I will have a custom one ground
I finally got the pics to upload so here you go
Posted on: 2007/2/28 11:22
Well i got an A-15 today so I will start the build for the coupe, The body work is almost complete just need to decide on colors and purchase paint. I was wondering about the roller rockers for the a-15 and what I need to lighting on the valve train?
Posted on: 2007/3/25 18:18
Give these guys a call.
DELTA CAM
They are in Tacoma. This is where I got mine. Cheap too! The Grind I got is what they call "D9" I can not recall the specs off the top of my head.
Less than $80.00
Posted on: 2007/3/25 21:07
I have a company that I can use really good prices I just need to give them some specs, i am also A dealer for Yella Terra rocker arms now and I thought I read some where that they make a-sereis roller rockers, but i havent found any thing yet
Posted on: 2007/3/25 21:38
