Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
what do ya do wen you lose lock nuts
flydato
Posted on: 2007/2/28 5:14
hey guys just bought my car and the other dude didnt give me lock nuts and there 14 inch hot wire's on my datto, wat do i do????????
#2
Re: what do ya do wen you lose lock nuts
beattie
Posted on: 2007/2/28 5:18
You have a couple of options
Hammer a socket of a close size over it. Or Hammer and chissel. Hammering sockets has always worked for me at work when customers loose locknuts
#3
Datto7
Posted on: 2007/2/28 5:21
If you have enough room, tack weld a bolt to the end of them and use a spanner as normal
#4
pepper
Posted on: 2007/2/28 5:41
buy a reverse spiral socket, works a treat.
#5
Posted on: 2007/2/28 5:45
cheapest is 2 or 4 21 mm sockets, hammer them on lightly and then undo... easier than hammer and chisel. if your lucky you can get away with hammering the socket off and using on another locknut till it gets stuck on there. i bought 4 and used 2.
#6
roblaw
Posted on: 2007/2/28 6:21
an ex girlfriend had the same problem with her mr2, so i told her to play dumb and take it to one of the bigger tyer shops in town, they had them off in 10mins and didn't even charge her a cent to get them off
#7
Coops
Posted on: 2007/2/28 6:34
Use an angle grinder to grind a couple of flats on the nut & use a open-ended spanner.
#8
phunkdoktaspok
Posted on: 2007/2/28 8:15
Do the other nuts up as tight as possible, then do the socket or chisel trick.
#9
flydato
Posted on: 2007/2/28 22:58
cheers guy's, the help will save me time, and a warning to other keep good care of your lock nuts!
#10
dat383
Posted on: 2007/3/1 3:11
gee some of you boys are rough.
use a smaller socket on a rattle gun and knock the old nut out after each one. You can view topic.
