A series camshafts!!
From Portugal
Hi there...
Does anybody know if a A13 camshaft will a A14 engine?
Any help would be apreciated.
Thanks alot
Fil
Posted on: 2007/3/2 16:25
Re: A series camshafts!!
From Selah, Washington
Hey Fil, I have a new one. Did you get the head yet?
Mike
Posted on: 2007/3/2 16:54
ALL A series cams from the 1974 & later design revision are directly interchangeable with each other, although the 'cam event' specs will vary from model to model. These are the 'rear positioned' distributor engines.
All 1974 & later A series cams can be used in the earlier A10 & 1200 engines if you abandon the original fuel pump & fit a blanking-off plate. [Front positioned distributor engines]
The earlier A10 & 1200 cams are not really useable in the 1974 & later engines as there is no gear to drive the rear positioned distributor on these cams.
Posted on: 2007/3/3 2:26
Love your Datsun.
Treat it well.
From Portugal
Thanks for your help...
Just bought a performance camshaft on ebay and it was listed to fit an A13 engine.
These are the specs:
INT. VALVE LIFT 441, EXH. 462. ADX. DURATION 270/280, @ .050 232/242. RPM RANGE 2200-5600, W/VALVE FLOAT @ 6200.
Do you think i will get any good results?
About the head,Bluemax, i know that it is already in Portugal.Now i have to pay some tax to get it.I
Posted on: 2007/3/3 16:39
From Bendigo, Victoria, Australia.
doesnt sound all that "performance" to me...
has a longer duration that the standard ones, but basically the same rev range as stock though
Posted on: 2007/3/3 20:23
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From Bunbury Western Australia
marginal increase for street but if you want to have your old cam reground check out www.swmotorsports.com.au, he can do a 54/86 cam grind for $120 roughly, heaps more power all the way to 8000-9000rpm, with properly built bottom end and valve train
Posted on: 2007/3/3 22:03
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Portugal
Well...i not an expert on cam specs and engine modifications, but all i want is litle bit more power for street use and i don
Posted on: 2007/3/4 5:25
From Portugal
Here are full specs from CraneCams:
CraneCams
Thanks
Fil
Posted on: 2007/3/4 5:48
From Adelaide, South Australia
Posted on: 2007/3/4 6:04
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Portugal
Thanks a lot Killer1200...
By the way...any idea wich will be the indicated compression rate?
Thanks
Fil
Posted on: 2007/3/4 15:32
(1) 2 3 »
