« 1 (2) 3 »
Re: A series camshafts!!
wich will be the diference i will notice in the engine
IF you keep the RPMs revved up you should notice a little bit more power. The stock carb and exhaust are limited to about 5,000 RPM. To notice more power you could:
- Change to a larger carburetor (like Weber DGV)
- Upgrade to 1.75" diameter exhaust
- Rev it over 5,000 rpm
Posted on: 2007/3/4 18:10
From Portugal
I
Posted on: 2007/3/5 3:37
What do you mean by "correct" compression rate?
In old times there was a lot of talk about higher duration cams "needing" more compression, but during the 90s it was proved you make more power, regardless of compression ratio.
The GX cylinder heads have larger chambers, so compression will drop a bit compared to the "premium gas" GX engine. You should have exactly what the "regular gas" GX (twin carb) engine had. All factory stuff, the camshaft seems similar too. See A12GX Engine
Posted on: 2007/3/5 7:51
From Portugal
I once saw a chart, i don
Posted on: 2007/3/5 10:21
From Malaysia
Hi Billy, abt the camshaft u bought. How much is it anyway from ebay?
Posted on: 2007/3/5 18:21
From Perth
two of mine...... sorry about the size
1st one is in the car now.... 2nd one was in there originally and might go back in when the racecar gets sold and the engine goes into my street wagon
Posted on: 2007/3/5 19:33
From Portugal
Thanks for the info...But i
Posted on: 2007/3/6 4:14
From UK
Whats the recommended cam specs for a blown A15, fast road?. I have heard its different from an NA.
Posted on: 2007/3/6 9:04
Capitalization is the difference between "I had to help my uncle Jack off a horse.." and "I had to help my uncle jack off a horse.."
From Perth
Whats the quality of fuel like in Portugal ?
Octane rating ?
Posted on: 2007/3/6 13:55
From Sydney
This is the specs I have for a A15 turbo. This is somewhere near what you are looking for>
Posted on: 2007/3/6 14:00
« 1 (2) 3 »
