Re: front end in 1200
From Wagga Wagga
good luck, in hay they don't give a stuff
Posted on: 2007/3/6 15:59
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
From Adelaide, Australia
quick questuion pigdog why are yu recommending not using stanza struts? are they to big?
Stanza struts need to be shortened, they are too long for a lowered 1200, I shortened the stanza struts in my partners car with 300zx kyb inserts and havent looked back.
Posted on: 2007/3/6 20:48
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From sydney,Australia
how do i get them shortened and what do you mean by this?
i got a set of stanza struts and a set of 120y struts/front end.
is there any way of using the stanza stuff on the 120y struts?eg calipers, rotors and everythign else
Posted on: 2007/3/6 23:11
On a lowered car, you run out of suspension travel when the strut leg is the standard length, this also means using shorter inserts.
Some people cut/weld the strut tube so you still have the thread at the top for the gland nut, some people cut the tube and retap the top (you need an engineer or machine shop to do this).
Posted on: 2007/3/6 23:16
IPRA Build
« 1 2 (3)
