Re: What are the benefits of a larger brake master cylinder?
From California
if your brakes are otherwise stock, then i don't see much point in changing things
unless you just wanted to add a booster which will make it so you need to apply less foot/leg pressure
if you increase caliper or piston size, then usually you want to increase master cylinder diameter to compensate
Posted on: 2007/3/7 5:55
Subject Poster Date
     What are the benefits of a larger brake master cylinder? matty 2007/3/7 1:56
       Re: What are the benefits of a larger brake master cylinder? Dodgeman 2007/3/7 3:04
         Re: What are the benefits of a larger brake master cylinder? matbighat 2007/3/7 5:55
           Re: What are the benefits of a larger brake master cylinder? matty 2007/3/7 9:48
             Re: What are the benefits of a larger brake master cylinder? PIGDOG 2007/3/7 14:15
             Re: What are the benefits of a larger brake master cylinder? BigD 2007/3/7 17:26
               Re: What are the benefits of a larger brake master cylinder? PIGDOG 2007/3/7 17:41
                 Re: What are the benefits of a larger brake master cylinder? BigD 2007/3/7 18:14
                   Re: What are the benefits of a larger brake master cylinder? dattodude 2007/3/7 18:18
                     Re: What are the benefits of a larger brake master cylinder? PIGDOG 2007/3/7 18:25
                       Re: What are the benefits of a larger brake master cylinder? Coops 2007/3/7 20:41
                         Re: What are the benefits of a larger brake master cylinder? short-coupe 2007/3/7 21:30
                           Re: What are the benefits of a larger brake master cylinder? matty 2007/3/8 1:24
                             Re: What are the benefits of a larger brake master cylinder? PIGDOG 2007/3/8 1:34
             Re: What are the benefits of a larger brake master cylinder? matbighat 2007/3/8 7:05
               Re: What are the benefits of a larger brake master cylinder? matty 2007/3/8 9:01
                 Re: What are the benefits of a larger brake master cylinder? matty 2007/3/8 9:13
                   Re: What are the benefits of a larger brake master cylinder? B210sleeper 2007/3/8 9:25
                     Re: What are the benefits of a larger brake master cylinder? PIGDOG 2007/3/8 15:27
                       Re: What are the benefits of a larger brake master cylinder? matty 2007/3/8 20:13
