A14 carb on an A12
From Toowoomba, australia
can any one tell me wat an a14 carb and intake manifold would be like on an A12?? i currently have a weber 32/36 dgav and it uses a hell of a lot of fuel and i cant put the a12 carb back on as i smashed it with a hammer cos i hate them also would i be better off working an a14 head for my a12 rather than the a12 head?
thanx
DAVE
Posted on: 2003/2/20 8:26
why go up and down when you can go round and round
Re: A14 carb on an A12
From sydney australia
the a12 carb without the pollution stuff was the best of the stock carby's,so it's a pity that you 'broke' it when you took it off.so,the next question is,what jets you running in the dgav,not stock 2 litre cortina ones.i'd try around the 115 main jet mark.oh & new jets are something like $3 each from Carbarettor Services in sydney,so you should be able to do some cheap fiddling,because any carby place should have a range of new ones.
Posted on: 2003/2/20 9:48
From Fort Worth, Texas, USA
I'm going to have to agree with b310gx in that if the Weber is tuned properly, it should run circles around the stock Hitachi carbs. I could be wrong though. Give the A-14 carb a go and if it doesn't work, tell us and we'll all know!
Posted on: 2003/2/20 17:00
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
B310gx is right, downsize the jets in your Weber and you'll get back your economy. I recommend getting a 'jet kit' with a selection of jets, so you can fine-tune it. You'll be glad you did.
The A14 and A12 carbs are both Hitachi 306s.
Will the A14 intake manifold fit your A12? Take a look at this:
Intake manifold comparo
Posted on: 2003/2/20 17:21
ok then cos i am running 140/140 jets at the moment. the carby is from a cortina race car. the jets were 180/255 i ran it like that for a day and it absolutely hammered. it also used 3/4 of a tank to go 50 k's
thanx guys
DAVE
Posted on: 2003/2/21 7:42
