What are the benefits of a larger brake master cylinder?
From brisbane
As the title suggests I am wondering what benefits I will see from going to a larger brake master cylinder. I am currently running an unboosted dual circuit 120Y model but I am thinking of putting a larger one on.
Thanks in advance Matty
Posted on: 2007/3/7 1:56
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: What are the benefits of a larger brake master cylinder?
The upside?
A larger diameter piston will displace a greater amount of fluid for a given amount of pedal travel. This will be good if the pedal currently travels a bit far, even when the brake shoes are fully & correctly adjusted.
The downside?
You will generate less line pressure for a given amount of pedal pressure, so in order to restore the previous level of line pressure, you will need to press harder on the pedal.
If the resulting pedal pressure is still within acceptable limits, then it's all good,but if, after a while, your right leg looks like Arnie Shwartzeneger's & your left looks like a normal persons, then you just gotta know that you need a booster with the new cylinder.
Posted on: 2007/3/7 3:04
Love your Datsun.
Treat it well.
From California
if your brakes are otherwise stock, then i don't see much point in changing things
unless you just wanted to add a booster which will make it so you need to apply less foot/leg pressure
if you increase caliper or piston size, then usually you want to increase master cylinder diameter to compensate
Posted on: 2007/3/7 5:55
From brisbane
Thanks guys.
I should have mentioned that I am running S13 Silvia front brakes and R31 Skyline rear brakes.
Matbighat - with the increase in caliper and piston size of my modified system will a bigger master cylinder allow increased braking force to be applied at the expense of extra effort on my behalf? Or, as Dodgeman has mentioned, will it just mean that the pedal doesn't travel as far?
Thanks again Matty
Posted on: 2007/3/7 9:48
From Geelong, Vic
you can sorta get more line pressure, just have to push the pedsal further, as the smaller bore master cant go as far as the big one, you get more pressure
but you would have locked the brakes up by then
if your still using single piston calipers all round i doubt that you would need a bigger master, im running 4 piston front and drum rear(until the diff is done) and a 7/8th master, the pedal is like a rock....has about an inch or 2 travel, if you push really hard
but the car is pretty well on its way to being stationary by then
Posted on: 2007/3/7 14:15
From NSW, Australia
I have just upgraded my datto booster/master and have a spare Nissan DR30 81model Skyline booster set-up in A1 cond. this was pulled from the 4 weel disk model. Im sure it will need some minor mods for it to bolt up, but thats what datto's are all about MOD'S So If your interested PM me.
Posted on: 2007/3/7 17:26
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
From Geelong, Vic
how bigs the skyline booster? would have thought it would be to big to use in a 1200
Posted on: 2007/3/7 17:41
From NSW, Australia
Its to big if your running a CA or SR, but with the good old A series there is room to spare. The guy i got it off rally's Datto's and he said the support on the back that bolts to the flywall needs to be shortened slightly to allow clearence of the strut tower.
Posted on: 2007/3/7 18:14
Cheers,
Big D
From Sydney, Australia
you get bigger calf muscles if it's your daily driver.
Posted on: 2007/3/7 18:18
From Geelong, Vic
yes, yes you do
Posted on: 2007/3/7 18:25
