Re: Behind the seats-what have you done?
From Melbourne AUS
from the factory rotaries (aka lawnmower engines) feed sump oil into the carby at a slow rate for lubrication.
when building my bridgeport we ditched the standard oil metering pump and i now run premix into the tank, rather than inject dirty sump oil. It burns cleaner and you know that your engine is recieving the lubrication it needs. its common for the factory setup to stop working or block up, and you wont know till its too late.
you get a lot of funny looks at the servo tho hehe
anyway back on topic
my ute has carpet all the way up the back panel and around the rear window which meets the roof lining. more of a felt than carpet should i say... i think thats what your question meant rather than whats sitting behind my seats ?
Posted on: 2007/3/6 1:17
1973 B110 A12
From brisbane
DemonFreeman - that's a very clever idea!
Posted on: 2007/3/6 10:10
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Wagga Wagga
just had a look theres a rag, WWII ammo can and about 6 empty packs of .22
Posted on: 2007/3/6 11:49
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
From Flinders View, QLD
I got a tool roll, tyre brace, bottle of water, couple of rags, the origional nissan tool bag??, a UBE (YOU BE hit with it YOU BE F##KED) some surface rust and some wiring. Wouldnt mind doing what demon did, sounds awsome. Might pull the seats out one weekend and have a good look at whats involved.
Posted on: 2007/3/6 17:25
Just trying to put the bloody puzzel back together
From sydney, northen beaches!
so is it easy to fit 6'9 in box behind the seats
Posted on: 2007/3/6 23:41
From NSW, Australia
Ive seen a Ute with the back extended also running 2 x Subs. Between the seats there is a polished amp and the doors fitted with splits and tweeders. it looked neat and tidy with great sound quality. I am looking into a custom console that comes up between the two seats (for an arm rest) and mounting some speakers on the two sides + doors.
Posted on: 2007/3/7 17:39
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
From Gold Coast
Thanks for the ideas guys... keep em comin! What ive been thinkin of doin for a while is to carpet the back wall in black (same colour as the carpet) and screw a piece of stainless/alluminium and have the datsun logo etched or watercut into it! what do yas think? i dont want it to look too ricey..coz its a datsun!
Wardy
Posted on: 2007/3/7 19:24
If you get new moulded carpets out of a 1200 sedan, the rear section will fit nicely just up under the lip 1/4 of the way up(you will need to use contact adhisive to make it stay put) Heat the backing to bend it.
Posted on: 2007/3/8 1:03
From Far, far away
Should be right, stainless isn't ricey (to expensive for the plastic brigade).
Anyone got picks of some extension work? We're getting a tubbed tray and backing fabricated and I just wanna see what the interior would look like.
I'm sure Wardy wouldn't mind seeing these as well.
Posted on: 2007/3/8 1:12
From Gold Coast
Nope i wouldnt..Get some pics up if yas have any..
Posted on: 2007/3/8 1:21
« 1 (2)
