#1 best way to block head coolant jackets
beattie Posted on: 2007/3/10 16:38
Well i finnaly got the A15 running!!!
Just that the manifold i got my hands on doesnt have coolant galleries, but the head has 3 holes for coolant to pass through. I tried a nice blob of silicone(i know i know) but it blew it out as soon as i revved it
What can i do fellas?
I also have a vannette manifold that has the galleries but in order for it to clear the extracters i have to cut it away where the coolant gallery is... Maybe i could block that somehow?
#2 Re: best way to block head coolant jackets
Tyrie Posted on: 2007/3/10 18:11
grub screws? I used little welch plugs in my L20B, but the holes were much bigger.
#3 Re: best way to block head coolant jackets
Graemes50 Posted on: 2007/3/10 18:36
How big/little are these holes?
I'm thinking of tapping them to suit a brass plug, say 1/8" BSP for example.
Coupled with a dose of thread sealant you should be on a winner.
You will need something mecahanically robust as you have already determined.
#4 Re: best way to block head coolant jackets
beattie Posted on: 2007/3/10 19:24
yeh what i ended up doing is tapping the holes and cut down a bolt into 3 sections and hack sawed a flat in it so i could screw it in flush. I used a touch of blue-poo just to be sure.
It had 3 smaller holes in the head.
#5 Re: best way to block head coolant jackets
TnPshow Posted on: 2007/3/10 22:09
Hylomar (the blue stuff they use to block the inlet ports in Peripheral Port rotaries) would fo the job nicely also...
Maybe overkill though
#6 Re: best way to block head coolant jackets
killer1200 Posted on: 2007/3/11 1:38
Im thinking the best thing to use would be a pipe plug just tap it when put it in.
#7 Re: best way to block head coolant jackets
ddgonzal Posted on: 2007/3/11 4:53
The *best* way -- which is not the cheapest or easiest -- if to use an intake manifold that covers the holes. For example, the Tomei twin-DCOE manifold does this. It doesn't have coolant passages, but the mounting face goes down over the ones in the head. So a stock A14 or A12GX gasket works with it.
#8 Re: best way to block head coolant jackets
Tyrie Posted on: 2007/3/11 7:23
I dont think Hylomar sticks to Alloy heads though...
