#1 What injectors can b ran on ca18det?
Laney Posted on: 2007/3/12 11:04
i lookin 4 sum info on what injectors can b ran on a ca18det or if sum1 has sum bigger ones 4 sale?
#2 Re: What injectors can b ran on ca18det?
Whorida Posted on: 2007/3/12 11:52
Someone correct me if I'm wrong, but I'm sure I've seen R32 GTR injectors used. Not sure of the volume, but definitely bigger.
#3 Re: What injectors can b ran on ca18det?
datb110 Posted on: 2007/3/12 13:00
Yeah its the rb26 injectors. Good upgrade, im looking into doing this if i can find sum at the right price. Not sure of the size of them though ?
#4 Re: What injectors can b ran on ca18det?
sikdatto1200 Posted on: 2007/3/12 14:03
from memory i think they are 440s, someone correct me if im wrong!
#5 Re: What injectors can b ran on ca18det?
scottyb Posted on: 2007/3/12 14:30
I think that 13B injectors can be used as well - correct me if im wrong tho....
#6 Re: What injectors can b ran on ca18det?
LAGWAGON Posted on: 2007/3/12 14:53
there's a lot of correct me if i'm wrongs going on
R32 GTR 440 or 444 depending on who you speak to.
13b turbo 550cc
12a turbo 880cc
all 'bolt in'
any top feed injector will work, the GTR ones should set you back around $200 for the set of four
#7 Re: What injectors can b ran on ca18det?
sikdatto1200 Posted on: 2007/3/12 15:27
well cant say i got the best memory Another option might be supra 7mgte 430cc injectors, there top feed also, low impedance. Pritty common, glad lags cleared it all up!
#8 Re: What injectors can b ran on ca18det?
Whorida Posted on: 2007/3/12 17:52
Yeah, thanks Lags. Can you help us out with this Q boys, whats the diff with cc's, bigger isn't always better right?
#9 Re: What injectors can b ran on ca18det?
sikdatto1200 Posted on: 2007/3/13 8:15
Well from my understanding the bigger the injector the poorer it will run down low/idle but with the extra flow you can make a ton of power. But in saying that it would be a bit overkill running 550s on an na a12. Manufactures usually only leave 10-20% extra flow in the stock fuel system this way maintaining best idle, smoothness, economy etc.
#10 Re: What injectors can b ran on ca18det?
Whorida Posted on: 2007/3/13 8:21
Cheers bro, that makes perfect sense. The RB26 injectors should be the way to go for the CA then.
