Re: a12 making crazy power @rebels dyno comp in QLD
From perf
comparing to other cars on the same dyno is not a good idea since we have no idea on their particulars. for eg the ca that made 307, what has been done to it, what boost is it running?? all cars could have had exagerated figures compared to mods.
you mentioned it was tuned the week before, what did it make then and was it on the same dyno?
the 195 carby set-up is again very impressive!
Posted on: 2007/3/12 10:34
From South Africa
This is some really good ####.... I would imagine the pistons being of a bit higher strength. he is running at about the boost levels I'm at and I'm pretty sure my A15 is not even in the parking lot of that ball-park.
I can not imagine how porting can make such a massive difference. but from that video, the way the run sounded, you can actually see that it is making massive power, and for it to pull through 3rd that fast.... so fast that some might even think it 2nd gear.... that to me, said it all... even if the actual figures are off.... that thing kicks ASS big-time....
Posted on: 2007/3/12 14:12
From adelaide
bloody hell, thats absolutly outstanding, who would have thought that would be possible, even for one run! Id be interested to no what the compression ratio is, what a sleeper
Posted on: 2007/3/12 15:56
1200 restoration project moving slower than it actually is
From Tamworth, NSW
I would say who ever did that head is going to have a few customers soon...
Posted on: 2007/3/12 16:31
Project coupe:
Just drive it
tappet wrote:
Can u believe this????
my mate was meant to have his a14 ready for the rebels dyno comp in QLD but could not get it done in time...
he had to settle with the stock old smokey a12 bottom end with some really schmick bolt ons...
Ahh sees it, but ahh doan beeleeeeve it.
L18_B110 wrote:
having messed around with a couple of turbo A series engines, I'm very impressed that a stock A12 piston managed to survive even one dyno run at 18psi!
And this would be one reason why. These are just low cost hypo eutectic cast alloy pistons in a "stock, old smokey A12 bottom end", & if it really is smokey, then those tired old rings did a dazzling job of holding onto that power at 18psi of boost, not once, but at least twice.
The pistons should be preserved for posterity.
I don't doubt that this engine pushed out that record power figure on that dyno, but I do have my suspicions about it being on a "stock, old smokey A12 bottom end"
Sorry for the scepticism, but it's just a bit hard to grasp.
Posted on: 2007/3/12 19:10
Love your Datsun.
Treat it well.
From Geelong, Vic
well my computers to slow for me to watch the video
but dodgeman has a good point about the bottom end, my brother managed to kill the rings and crack the ring journals off one of the pistons in his healthy 3tc when it was under somewhere between 10-15psi
but the first few seconds of that video made the car look nice and powerful
Posted on: 2007/3/12 19:28
My comments are based on the description provided, which leads me to assume that a well used, original A12 short block was pulled from under the bench & fitted with all the goodies, but did not receive so much as a re-ring, bore hone or replacement bearings, so we don't even want to mention a balance job.
Just a stock, old smokey A12 bottom end.
Posted on: 2007/3/12 19:35
Love your Datsun.
Treat it well.
From Brissy
thats absolutly correct...
a dirty old bog stock a12 bottom end, cast pistons, definatly no balancing.... i will have a pic of the mighty beast when it comes out for the a14 engine..
Posted on: 2007/3/12 19:55
From South Africa, Bloemfontein
Are you sure it is the standard A12 cylinder head?
Not maybe a Big port GX or A15 cylinder head fitted?
If it is true, congratulations.
I just wonder, how long will the engine last with that power figure and boost level.
Now that is a thought.
Before you put in the A14, won't you play a bit with the car and see how long the A12 last?
Take to a drag race event or something.
Give it some hammering and test for us the reliability factor.
Posted on: 2007/3/12 20:06
1977 Datsun 1200GX
From south australia
i think he has already stated that it has had porting and valve work. it is the bottem end that is standard
Posted on: 2007/3/12 20:12
« 1 2 3 4 (5) 6 7 »
