evilbetty. if i painted my ute in a flat black 2 pak could i mix in a purple pearl in witht the final coat to get a flat black car with a heavy purple pearl?
hay there mate,sorry cant help you with that part number all i know is they fit an old ford cortina,best so go to bursons and get them to go thru there books,as for the pearl,
you want flat black with pearl????????????thats a new one,well personaly mate i wouldnt try that as you could end with a bit of a mess,you could spray 2 pak black and then put a coat of clear over the top with pearl in it how ever you would have to know what you are doing as you have to spray the clear very even or it too wont turn out that well,for this i would sugest using a base coat system ,that is paint it basecoat black with matting base in it(mating base is a product that will take the gloss out of the paint ,)then paint a layer of pearl over the top of that ,then clear it with 2 pak clear with mating base in it also ,a bit of a stuff around ,why are you after a flat finish???it would be alot easyer for you if you go full gloss .easpecialy for pearls,good luck with what ever you decided on
