Re: holden V6 1200
From Far, far away
Those are some serious flares!
Posted on: 2007/3/16 2:27
Re: holden V6 1200
From Geelong, Vic
yeah, apperently flaring is cheaper than getting a diff cut down
Posted on: 2007/3/16 2:31
Re: holden V6 1200
From Adelaide, SA
That was for sale on my105.com recently.
They were asking about $7k if I remember rightly....
Posted on: 2007/3/16 2:47
Re: holden V6 1200
GM 3800 V6 in Datsun 1200
click me
Posted on: 2007/3/16 4:13
Re: holden V6 1200
From Adelaide, South Australia
TnPshow wrote:
There's a ute here in Adelaide with the same motor getting about but no details on it unfortunately...
Definately can be done though
That was for sale about 3 years ago for 3.5k.
Posted on: 2007/3/16 4:41
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
Re: holden V6 1200
Quite a regular
From Toowoomba
does anyone know who owns that yellow masterpiece??? Looks awesome, would like some pointers!
Posted on: 2007/3/16 12:38
Re: holden V6 1200
From Geelong, Vic
dont know who owns it, but what do you want pointers on?
Posted on: 2007/3/16 12:45
Re: holden V6 1200
Quite a regular
From Toowoomba
what gearbox?
how did they get the radiator to fit without cutting the front of the car? measured mine up and will be a real tight squeeze even if i do cut it!
did they have to modify the cross member and engine mounts?
Or am i just not thinking about it hard enough?
Posted on: 2007/3/16 12:57
Re: holden V6 1200
The obvious choice for gearbox is the automatic that comes with the 3800. Just cut out the tunnel and use a large piece of sheet metal to re-cover it.
There should be plenty of room for a radiator as the engine is only 3-1/2 cylinders long. Especially if electric fans are used.
Posted on: 2007/3/16 14:51
Re: holden V6 1200
From Geelong, Vic
yeah use a vn auto of t5 5 speed also from a vn
what exactly do you mean by cut the front out...
the vn radiator will fit between the chassis rails and just clear the bonnet, so its a great fit...and they have a little bit of room left over between the enigne and the radiator, not heaps though
but you will probably want to cut the radiator suport panel out so that it gets some airflow
yes you will have to modfiy the engine mounts and crossmember....as with 99% of engine conversions
mines just solid mounted as the vn engine mounts and huge and i didnt want to stuff around fitting them in
Posted on: 2007/3/16 21:41
« 1 (2)
