Re: Dead 1200
From Sydney
Hmmm when u say bag of #### lol, does it seam to run like engine should( just really badly) or all over the shot like its just a bunch of explosions that by fluke turn engine over. my only ideas from hear are to remove valve cover and turn engine over by hand and make sure valve train is doin wat it should.
if it was compression i would still think it shoud kick and possible run thats my thoughs anyway.
Posted on: 2007/3/19 1:03
Re: Dead 1200
Quite a regular
From Toowoomba
All over the place and backfiring like you wouldn't believe!
head has been off and all seems ok!
I'm seriously thinking about turfing this motor and putting something else in there!!! Gettin seriously pissed off with it!!
Posted on: 2007/3/19 1:07
If you can't beat 'em,
Arrange to have 'em beaten!
Re: Dead 1200
I was driving home one afternoon and my motor just stopped!
Snapped timing chain?
Posted on: 2007/3/19 1:14
Re: Dead 1200
From Sydney
just take to it with a big hammer,that will fix it lol. i suspect its ur cam or timming gear easy thing to check is to take dizzy out inspect gear on end possible look down the hole and turn engine over see if cam rotates(u'll need a torch)
Re: Dead 1200
From Bunbury Western Australia
but if it was the valve train he wouldnt have spark
Posted on: 2007/3/19 1:22
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Re: Dead 1200
you didn't happen to fill your tank with diesel before hand did you this is a bit of a different dilema that I am used to
Posted on: 2007/3/19 1:25
Re: Dead 1200
Quite a regular
From Toowoomba
That hammer is sounding like a damn good idea!! I'm serious!!!
I was thinking, could it be the dizzy? That is one thing that hasn't been replaced but the points have been!
Timing cover was taken off and, again, all seems ok! had also thought that it was something internal, what sort of things are there inside the motor that could cause this? as everything attached to, or is a part of the motor has either been replaced or checked at least 10 times! was mentioned before about the compression, it hasn't been compression tested. could that be the problem?
Re: Dead 1200
Quite a regular
From Toowoomba
HaHaHa!!! No! Strictly Ultimate!
Posted on: 2007/3/19 1:26
Re: Dead 1200
If the compression is down it definately wouldn't help the situation
dizzy is drivven from the cam shaft, fuel pump is driven from the camshaft unless yours is electric, could always check valve clearances incase an exhaust rocker has adjusted it self down over time by vibration, holding an exhaust valve open slightly causing it to backfire (happened on my old 200B burnout wreck)
One way to check distributor function is to check for spark at each plug and then check ignition timing while turning it over by the starter motor so you can see if the spark is happening at the right time to make the engine start.
The way it sounds if the motor just died like that it sounds either spark or mechanical related, no dropped valves? any weird noises?
Posted on: 2007/3/19 1:34
Re: Dead 1200
Quite a regular
From Toowoomba
No noises whatsoever. Just died around the corner from my house so I managed to push it home and thats where the fun started!
think i'm going to have to change motors, everything that has been suggested has been tried, (except for the compression) but thank you all for your help!! if there are any other ideas please let me know.
Cheers, Renee.
Posted on: 2007/3/19 1:43
« 1 (2) 3 4 »
