« 1 2 (3) 4 5 6 ... 21 »
Re: A-Series Manifold Templates for Autocad - Come n get 'em
From Christchurch NZ
I have a mate who works for a profile cutting company. The boys on the floor do foreigners for beer. I'm waiting on my rear disc brake caliper mounting plates at the moment.
Posted on: 2007/3/20 4:26
Forced Induction!
From Adelaide, SA
Bump!
I've got files out to 4 places for quotation at the moment. I'll post prices here when they come in
Posted on: 2007/3/20 4:48
From Adelaide, SA
Ok just got the 1st quote back.
I modded the files so they had supports to hold the pieces together during welding like this:
Programming cost $10, prices include GST
Inlet - 5 off - 10mm 5083 Aluminium - $38.61 ea
Inlet - 10 off - 10mm 5083 Al - $35.31ea
Inet - 20 off - 10mm 5083 Al - $33.66ea
Exhaust - 5 off - 10mm Mild Steel - $18.39ea
Exhaust - 10 off - 10mm Mild Steel - $13.86ea
Exhaust - 20 off - 10mm Mild Steel - $11.59ea
Minimum order is $75, so even 5 - off is feasible.
Posted on: 2007/3/20 21:28
From Freo
have you got a file for the new ones?
cheers, Mike
Posted on: 2007/3/20 22:31
From Adelaide, SA
Yep:
Exhaust
Inlet
Just wondering if I should get the loose pieces quoted (without the hang-on brackets). Should bring the cost down on the inlet a bit....
Posted on: 2007/3/20 22:55
good prices.
especially for the inlet in which you can weld up 4 tubes and use bike carbs.
Posted on: 2007/3/21 0:00
From Freo
and that only leaves a roundport one witht the joins like the oval,
cheers,
Posted on: 2007/3/21 0:22
From Perth
I would take 2 inlet and 2 exhausts
Posted on: 2007/3/21 2:57
From Christchurch. NZ
I'd be keen for an inlet one.
Posted on: 2007/3/21 3:16
From Tamworth, NSW
Dattoman_1000 I:2 E: 2
dattodevil I: 1
pager I: 1 E: 1
Just copy and paste and add your name to it and how many you want
Posted on: 2007/3/21 3:26
Project coupe:
Just drive it
