#1 1200 calipers
SPANNERNUT Posted on: 2007/3/21 15:28
just stripped calipers fluid leaking out of inner piston cant see any seal on it the one next to pad is it meant to have a seal ????never seen a caliper with 2 pistons need info {no brake manual} help
#2 Re: 1200 calipers
Mildman Posted on: 2007/3/21 17:14
There is a seal between the piston and the cylinder wall the piston is housed in.
Check the Brakes section on this site - you can see some brake calipers getting rebuilt....it's for a Torana - but they are also a twin piston caliper.
http://mildman.datsunprojects.org/Lockrice/index.htm
#3 Re: 1200 calipers
SPANNERNUT Posted on: 2007/3/21 17:41
THANKS BUT THE PISTONS ON MY CALIPERS ARE IN THE SAME SLEEVE NEVER SEEN ANYTHING LIKE IT THEY ON EACH END OF SLEEVE 1 PULLS THE OUTER PAD THE OTHER ACTS AS A SECONDARY EMERGENCY BRAKE I THINK IT CAN'T BE SPLIT NOTHING LIKE YOU'RE CALIPER
#4 Re: 1200 calipers
TnPshow Posted on: 2007/3/21 21:48
Can you post or email a picture of your caliper? It doesn't sound like a factory 1200 one...
#5 Re: 1200 calipers
PIGDOG Posted on: 2007/3/21 21:58
yeah its the standard jap caliper, same as 120y sunny and 180b calipers
there is a seal at each end of the sleeve things, one for each piston
