Getting ever closer to blowing it up. Got a 1:1 pulley for the blower and bolted it together. the belt length came to 1260-1285 range which is not available in a 5pk, so I got a 6pk and cut a rib off it
off for a drive- tinktinktink.
nurse it home.
pull outb 5 deg of timing- bwwwwaaaaatinktinktink
nurse it home.
add bucketloads of fuel to the primary circuit (127 to 140 jet) and pull out another 2 degrees of timing, and add some colder plugs.
bwwwwaaaaaaaaaatinkaaaaaaaahhhhhhbwbwsbswbswsbswsbsw
blowing the flame out through the top end and still some detonation on transition/ through the bottom. making just over 10psi
Pulled out so much timing that it is only slightly quicker than it was at 5psi.
need to close the plug gaps up (or get a better ignition system) get some water injection sussed out, and most importantly, recurve the dizzy for less total advance (if possible) and slower progression of advance.
Don't really want to put a head shim in to decompress it, but It may be an easy/cheap option compared to water injection.
