Re: nissan vanette diff help
From South East QLD
so does that mean a stanza diff is too wide for a 1200?
its to wide with out flares .. but works out ok with flares at the rear
Posted on: 2007/3/23 6:58
From Bunbury Western Australia
or fwd offset wheels
Posted on: 2007/3/24 5:16
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Christchurch. NZ
Well I know for sure the earlier C20 vanette is 100mm wider (total). If that helps. If you are fitting to a 1200 then you just need to move the platforms in 25mm and decrease the spring platform width by 10 mm, from 60mm to 50mm. you also need to move the brake pipe union mount from right to left. For a 120Y I am unsure.
Posted on: 2007/3/24 5:27
From Portugal
ok , thanks to all
Posted on: 2007/3/24 10:41
« 1 (2)
