Wanted: 1000 coupe wiring diagram!!!
From Perth WA
Well ive just put a kb10 dash into the wagon. I got the kb10 loom and everything... theres just some odd wires and things I cant find a wiring diagram on the net, genuine b10 manual, gregory's 1000 manual or a b10 parts book. So im guessing the only place left is in a kb10 owners manual? Or some other external source?
Thanks guys!
Posted on: 2007/3/25 3:45
Chris...
Re: Wanted: 1000 coupe wiring diagram!!!
From Adelaide, SA
I'd scan you mine but I've lent my scanner to someone - sorry!
Dodgeman - where are you???
Posted on: 2007/3/25 4:43
From Freo
i've got an owner's manual,
I'll have to find it though..
can't be far..
Posted on: 2007/3/25 6:35
From Freo
or I guess you could crawl thru a couple of coupes i have.. :P
Posted on: 2007/3/25 6:40
I have scaned the wiring diagram in my owners manual in a fairly high resolution, & a second scan in an even higher resolution, then sent both off to beattie in an e-mail.
One image should fill the screen, while the other can be blown up quite large in Windows without loss of quality. Quite large indeed.
The file size is a bit big to post here & if I reduce it to fit, it becomes a bit too hard to read.
If anyone wants a copy, then drop me an e-mail so that I can send them in a return.
Posted on: 2007/3/25 6:44
Love your Datsun.
Treat it well.
From Perth WA
Champion! Thanks man!
Posted on: 2007/3/25 6:46
Chris...
From Freo
how did u mount the dash? the coupe is quite different behind the crash pad?
Posted on: 2007/3/25 6:48
The coupe dash will fit right into the body shell right where the old one comes out. Once it's in, you just install the crash pad, the coupe instrument cluster & all the trimmings.
The hard part is in removing the coupe dash panel without damaging it as it's welded into the body shell if I remember rightly.
Posted on: 2007/3/25 7:03
Love your Datsun.
Treat it well.
From Freo
thats what I thought, more than just a bolt in,
I've got a few I could practice on,
but i'm kinda hoping somebody will do a deal on them all and resurect one or two, even if they were to race..
Posted on: 2007/3/25 7:08
From Perth WA
Yeh weld it in...
What i did was get all the things i need for $50 off a mate. then i cut the original dash out leaving about 2" protruding from where the windscreen sits. Then i cut the coupe dash just on the line between the flat part of the dash meets the bit where its spot welded. then i sat it on the 2" lip and pushed it right into the corner and used 4 tech-screws to hold her down.
Easy as that. I might take some more pics tomorro and post em up!
Posted on: 2007/3/25 7:18
Chris...
