« 1 (2)
#11 Re: A series turbo manifold wanted
sidedraught Posted on: 2007/3/24 22:37
Now this is about as primitive as it gets but it shows just how easy it ican be.
To make it easier put an SU right in front of the turbo, then its an afternoons work all up.
#12 Re: A series turbo manifold wanted
WARDY Posted on: 2007/3/24 23:41
Oh ok yeah that looks pretty simple.. i have a 13/4 inch su at my dads shop.. will that be sufficient? I plan to just turbo the stock A12 atm.. while i build up a tuff A15. How much power could i expect from say a Hot A15 with a T28 or T3 running around 15-20psi boost?
#13 Re: A series turbo manifold wanted
kegs Posted on: 2007/3/24 23:46
bro stick with the t25 the two others wont spool up i have a great cond t25 here if u want that pm me if ur keen.
#14 Re: A series turbo manifold wanted
WARDY Posted on: 2007/3/24 23:58
Oh ok sweet.. so u think a T28 would be too big for a worked A15?? i had a T3 on my efi L20 datto 1600 and i thought it was a great turbo for the money.. but i suppose it has a bit of a cc advantage haha.. what about a T28bb off a S15 import? i can get one of these pretty easy..
#15 Re: A series turbo manifold wanted
WARDY Posted on: 2007/3/26 6:30
Come on guys has anyone got one or kno of where one is?? Getting pretty desperate as i want to start getting the engine ready to bolt in!!
I have everything else sorted i jus need the manifold..
Cheers Wardy
#16 Re: A series turbo manifold wanted
Talasas Posted on: 2007/3/26 16:49
You can't just build one? I built one and it took me about 2 days for my car. Not a datto tho.
#17 Re: A series turbo manifold wanted
picko Posted on: 2007/3/26 19:09
i currently have a t25 on my 1400 that i will be getting rid of with manifold and maybe dump pipe as soon as i can find a t28 out of a s15. you mentioned you can get one easy enough. from where? i have been looking but with no luck!
« 1 (2)
