Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
alternator bracket??? where do i bolt it on?
Matto1kUte
Posted on: 2007/3/26 22:20
hi guys ive got a A15 with a new head on it but the only thing is that there is no where to bolt the alternator bracket back on the head. what did u guys do. is there somthing i can just buy?
#2
Re: alternator bracket??? where do i bolt it on?
WhiteSedan
Posted on: 2007/3/27 0:29
What side are you running the alt on?
#3
pepper
Posted on: 2007/3/27 0:31
you dont bolt it to the head, it bolts to the block, the top adjuster bracket is bolted to the head
#4
beattie
Posted on: 2007/3/27 0:35
You wont be able to bolt it straight to the passenger side (as in early block) you have to make a adapter plate up like i did.
To bolt it to the drivers side(RH) there are 2 threaded holes in the block and the adjuster goes in a hole in the head just under the thermostat housing
#5
cheater_5
Posted on: 2007/3/27 1:17
hey not meaning to hijack thread at all but im going to be running my alt on the lef thand side as on the a12... can i use the a12 mount?
If not can i get a pic of the bracket i need?? would help a lot. Cheers
#6
beattie
Posted on: 2007/3/27 1:26
I used the original (1000 mount in my case) but just made a plate out of 3mm plate to make it sit in the original spot and bolt to the block. Pretty easy really, just make sure you have your holes in the right spot or your pullies will be out of whack!
If you still want a pic i can take one of mine when i get back from sydney in a week.
#7
cheater_5
Posted on: 2007/3/27 1:46
yea thatd be sweet thanks bettie.
anyone else done it ?
#8
WhiteSedan
Posted on: 2007/3/27 2:20
Ive got a A12 (120y item) with the alt on the manifold side, previous owner has done what beattie has done and used a thick plate and bolted the original mount to it, mines out of wack about a mm or so. When i get round to it i will fix that.
#9
Matto1kUte
Posted on: 2007/3/27 17:38
i was thinkin of using the bolt on the thermo housing
